20 Most Recent D-Link Securicam Network DCS-950G Wireless Internet Camera Questions & Answers
Wireless security
Hello sir,
GETTING STARTED How to Physically Connect the D-Link
1. Plug an Ethernet cable into the DSL modem. Plug the other end of the cable into the "WAN" port on the D-Link.
2. Using an Ethernet cable, plug any wired computers into any of the 4 Ethernet ports on the D-Link.
How to Access the D-Link Configuration Screen
The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps:
1. Launch your Web browser. Enter "http://192.168.0.1" into the address bar and press the "Enter" or "Return" key.
2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
GENERAL SECURITY MEASURES
Change the Admin password
Leaving the password blank is not a good idea. It should be changed to something more secure. To change the password, go to the D-Link configuration screen and:
1. Click the "Tools" tab.
2. Click the "Admin" button.
3. Under the "Administrator" heading, enter the new password, and a second time to confirm.
4. Click "Apply".
5. The next time you access the D-Link configuration screen, you will need to enter the new Admin password.
Disable the Wireless LAN
If wireless access is not necessary, you should disable the wireless part of the D-Link. This will prevent anyone from accessing the network wirelessly. (If you are using the wireless features, please skip down to "Wireless Security Measures".) From the D-Link configuration screen:
1. Click the "Home" tab.
2. Click the "Wireless" button.
3. Click the "Disabled" button next to "Wireless Radio".
4. Click "Apply".
5. You are done securing your wired network. No further action is required.
WIRELESS SECURITY MEASURES
Enable WEP
Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
3. Click the "Open System" button next to "Authentication".
4. Set the "WEP Encryption" to "128 bit".
5. Set the "Key Type" to "ASCII".
6. Type a 13 digit password into "Key 1".
7. Click "Apply".
8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
*Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
Change the SSID
By default, the D-Link is set to advertise the existence of your wireless network to computers. It does this by broadcasting an SSID (Service Set Identifier), also called a "network name" because it identifies your wireless network. Changing the SSID makes it easier for you to distinguish your network from surrounding networks. From the D-Link configuration screen:
3. Change the "SSID" from "default" to an SSID of your choice.
4. Click "Apply".
Please don't forget to comment this
Good luck
Cheers!!!!!!!!!!
7/19/2019 12:10:02 PM • D-Link Securicam... • Answered on Jul 19, 2019
D-Link DSC-950 I can not get ip and password. You
Here is the User Manual for D-Link DSC-950G ftp://ftp.dlink.ru/pub/Multimedia/DCS-950G/Description/DCS-950G_manual_07062005.pdf For Future Support Visit:- https://www.youtube.com/channel/UCxAhv5XWrbpjvdfVBVEHCMA
9/19/2017 11:09:06 AM • D-Link Securicam... • Answered on Sep 19, 2017
How do i setup my
get free online support for setup your camera. Visit:- CCTV Networking Technical Support
9/19/2017 11:05:47 AM • D-Link Securicam... • Answered on Sep 19, 2017
Can't view IP cam externally
Follow The Process:- 1.Visit https://www.yougetsignal.com/tools/open-ports input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem. 2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website. Visit Here for next level help:- CCTV Networking Technical Support
9/19/2017 11:04:57 AM • D-Link Securicam... • Answered on Sep 19, 2017
Security First SDVS-1904 Setup
I'm not sure if you are still looking for the answer, but I think the problem may be that you need to enter the PUBLIC IP address of the modem at the remote end instead of the PRIVATE (ie. 192.168.1.x) IP that was actually assigned to the DVR. It works best if you assign a static IP to the DVR on the remote end and enter that IP into the router's DMZ. You might also want to get a free account at dyndns.net and setup a FQDN for your business router/modem. That way you can connect to it using something like "mybusiness.homeip.net" instead of an IP address, and if the IP changes it will still find it. You will also have to configure your modem at the business to automatically update the dyndns server when the IP changes.
9/8/2010 3:38:59 PM • D-Link Securicam... • Answered on Sep 08, 2010
Signal doesn't appear strong enough into motel
yes
10/25/2009 7:33:45 AM • D-Link Securicam... • Answered on Oct 25, 2009
Audio
This may be a feedback issue if you are playing bsck the audio from the camera in the same room the camera is located in. Turn down the speaker volume or turn them off.
6/15/2009 5:21:21 PM • D-Link Securicam... • Answered on Jun 15, 2009
Currently 7 people living in
The most likely problem is that the software that the camera uses is limited as to the number of simultaneous users. You could upgrade to a simple Pelco or Dedicated Micros server, and then the number of users can be in the hundreds, I believe. Let me know through a post if this is not the problem.
9/30/2008 6:04:59 PM • D-Link Securicam... • Answered on Sep 30, 2008
I am using my htc android's hotspot to power all of my wifi gadgets in my home. I just bought bunker Hill H.264 DVR security system and am trying to configure it to my phone for remote viewing. Pl
You need P2P Cloud Setup. DDNS Service will not work. no option to port forward in mobile or mobile isp use firewall block users to access connect directly to internet. Visit:- https://www.youtube.com/channel/UCxAhv5XWrbpjvdfVBVEHCMA
9/19/2017 11:16:38 AM • D-Link Home... • Answered on Sep 19, 2017
I want to run my d-link camera for security in my
D-Link has a web site and all of the software that you may need. The problem with D-Link is that when it updates firmware, you will have to reconnect your "wireless" unit to your computer. PIA !
5/30/2017 10:08:58 PM • D-Link Home... • Answered on May 30, 2017
What are some common types of sensors and detectors used in security systems, and how do they function?
Nice question. Do you have a specific concern, or an area to protect? I am an expert by experience.
The Various Types of sensors used in the Security Alarm ...
ResearchGate https://www.researchgate.net > publication > 34047974... Apr 7, 2020 - Microwave sensor (2) Vibration Sensors: Vibration sensors are sensors that are used for displaying, measuring, and evaluating linear velocity, ... ..
4/13/2024 11:02:25 PM • Home Security • Answered on Apr 13, 2024
2answers
Why should you opt for wooden flooring to improve your interiors?
Wooden flooring is known for its elegant look. It creates a warm ambience inside your home. Hardwood floors are elements of d?cor themselves, which are available in many different types and colours. Its durability will ensure a good interior investment while providing aesthetics to your home.
4/1/2024 6:34:20 AM • Home Security • Answered on Apr 01, 2024
2answers
Have Model: SM-79. Serial# 7951889.Operating OK. Rust buildup lower left corner outer cover with woman picture and STEAMBATH letters under her picture. How should I address matter?
Like Steve stated. I would add to use a rust-converting primer (the type that converts surface rust into an invert primer, stopping all future rusting).
As this is only occurring in the left corner, I'd try to determine exactly where the water is coming from (that's causing the damage). I suppose it could be condensation if the unit is over ten years old, but it also possible that a connection slightly loose or worn.
3/23/2024 5:27:58 PM • Home Security • Answered on Mar 23, 2024
Contact phone number for paragon lock and safe company
(972) 288-7557 ยท (972) 222-0646 Email is better to make contact.
3/22/2024 8:47:59 PM • Home Security • Answered on Mar 22, 2024
Mibao P450 Security Camera. I need a manual for it please?
Question edited for clarity. Here is the manual Jules https://www.manualslib.com/products/Mibao-P450-12979047.html And set up videos ..
2/23/2024 8:29:39 PM • Home Security • Answered on Feb 23, 2024
Soliom Camera Night Issues- Soliom Troubleshooting?
Top 10 Troubleshooting Methods to Fix "Your Security ...
https://soliom.net > blogs > tips > top-10-troubleshootin...
Aug. 22, 2019 - Night vision doesn't work, can't record anything, or infrared is not working. Can't connect to NVR security camera on my iPhone/iPad. 24/7 ...
Soliom Troubleshooting Support Provides Instant Resolutions!
https://soliom-support.com > soliom-troubleshooting
If the Soliom camera does not work properly To Illustrate, as the lights are not on in dark at nights, it is likely a cable problem, and it will cause no video and no image recording at night. You can use another cable to connect the camera to see if the problem is solved.
2/22/2024 12:52:03 PM • Home Security • Answered on Feb 22, 2024
D-Link Securicam Network DCS-950G Wireless Internet Camera Logo
14 questions posted
Top D-Link Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a D-Link Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Home Security
Most Popular Question
wireless security
  • Home Security
