20 Most Recent
Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood Questions & Answers
Broken light switch on a Nutone
The Black 120vac Line In wire goes into "L". The Black wire goes into "2". The Red Wire goes into "3". When you install the switch, the Red and Black wires will be on top of the switch.
My range hood is making
I had the same problem.
What fixed it was I removed the aluminum filter so I could see the motor and fan. Sure enough, debris had fallen through and was inside. I removed the coter pin so the fan blades would slip off. Then pulled out the debris.
Haven't had any problems since.
Be sure to unplug the unit prior to servicing.
As fan picks up speed it seems to vibrate
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Whispaire - Fan stopped working
You would definetly be able to replace the motor yourself, if your a handy person.
1. You must take off the blade before starting which is only held on by pressure and a mini little metal clip at the tip of shaft.
2. Motor bracket is held on by 4 star/phillips headed screws, two are located under the metal plate the retains all the wires on the right side, and two located on the left side of motor housing.
3. The motor is wired with a plastic connector (plug in plug out). Once motor bracket has been unscrewed and removed there is 4 star/phillips screws holding the motor on the bracket.
Restart proceedure to install the new motor. Part #K7448-000
Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
