20 Most Recent
Sony Handycam DCR-DVD805 DVD Camcorder Questions & Answers
Can i charge handycam using
No you can't. You can only use the specific charger to charge your camcorder. You can only use the USB slot for transferring files.
Thanks for using Fixya!
I got picture package
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
I keep getting the message...'Recording
Try reading the disc on a computer that has a DVD drive - should be able to detect what files are on it. If you can't record anymore, then the disc probably got "finalized" on the camera.
I don't know how to
Install the Software of your camera in the your laptop by using the CD which came with your camera...after that whenever you will connect this will work finely...
My sony Handycam DCR-DVD805 is not working. On
The cameras that use DVD disks have a 89% break down rate, the media simply is not made for things we carry around like cameras, just grab a camera with tape that records your great movie films, the DVD idea is a sales idea from camera makers to grab your money, but the media simply does not seem to work mostly on cameras.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
