20 Most Recent
Phonic MAX 2500 Amplifier Questions & Answers
Hello, i need phonic max
archive.espec.ws/.../PHONIC%20MAX-%20860%201...
Traduire cette page
Phonic reserves the right to improve or alter any information supplied within ... MAX860/1500/2500 SERVICE MANUAL ..... HEAT SINK MAX SERIES PHONIC.
www.eserviceinfo.com/index.php?...PHONIC+max+2...
Traduire cette page
15 janv. 2009 - Search results for: PHONIC max 2500 (found: 50 regularSearch) ... Audio, 2891 kB, 2178, Service Manual, PHONIC max 2500, VASILICH500.
www.phonic.com > Home > Amplifiers > Analog
Traduire cette page
Phonic's MAX 2500 Plus Power Amplifier provides 1500 Watts of power at 8 ohms (bridge mono) or 750 ... MAX 2500 Plus Simplified Chinese User's Manual.
elektrotanya.com/phonic_max...2500.../download.ht...
Traduire cette page
PHONIC MAX 860 1500 2500. Sponsored link. Type: (PDF), Size 2.9 MB, Page 27, Category: AUDIO - SERVICE MANUAL. Warning! If you are not fa
Blown outputs how to fix
dont fix it your self you may be hurt by eletricity bring it to qualified personnal its safe and sure
Why is my speaker not working to full capacity
Hello, First, check the bridge switch located on the rear of the amplifier, should be on STEREO position, GROUND switch to GROUNDED position, check front potentiometer for dirt or scratchy sound as turned it up or down, if none of this solve your issue then could be an internal defective speaker output relay, or channel fuses, let me know if you need further assistance, Regards.
I have a Phonic Max
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
I want to connect Max 2500 with 6 JBL Control 28 speakers 175 watts @ 8 ohms each... please suggest what will be the best connection...series or parallel
first is how u want to run the amp itself ....... the MAX2500 can run in mono (bridged) output or stereo ......... though wat u want to watch is the impedance of the load really with the bridged load being no lower than 8 ohms/1500W (there's reasons for this) and the stereo load where u can have either 4 ohms/750W or 8 ohms/500W so how do u want to run this is first the question ..... all 6 on the bridged output or 2 off each channel (though running 3 would make for complicated impedance load) ..... so u'd run 2 in parallel for a 4 ohm load with 300 watt requirement from the amp and u can drive them to 1.5 times their rated RMS figure so a nice 500 watts :)
Phonic Max2500
you have real problem in safety contol circuit which shut down the unit to protect the amplifier from damage
