20 Most Recent
TurboChef C3 Single Oven Questions & Answers
I have a c3 oven
Very expensive mag required , buy tornado or i3 instead don't waste your money on c3
Turbochef
You can remove the bleeper from the pcb but you will destroy the food inside as you will forget to take it out it only takes seconds
Turbochef self test memory
My turbochef tornado gives an message of "Self Test Memory" and sometimes continue to warm up, sometimes no. Sometimes he is running ok and then he shutdown and the message appears again. Any suggestions?
High limit switch keeps triping on tornado oven
the K4/K5 relay tells the convection circuit AND the IR circuit to allow voltage to the elements.. if it is bad you will not get 1 or other or even both.. if you have convection heat and you are positive that the ir element and I/O board are good then swap the b1/b2 terminals with the a1/a2 terminals on that relay and retest.. if the IR now works then order the new K4/K5 relay. it is a common issue with them. the relay is behind the blower motor on the right side.. 3 screws to remove the blower and that relay is right behind it. it is the only relay with a single orange wire and the other 3 are blue.
How to program the buttons and times?
does oven need to reach its temp to program? what screens are you suppose to use to perpare food? need help programming the turbo c3!!!!
do you have any chefs that are in the west palm beach,fl area that could possible help us program this unit?
Where do i find parts - like fuse
go to 3wire.com recommended by IPC, also you get crazy deals. Be sure to register as a subway to get the subway discount.
This will save you hundreds of $$$$ so be sure to thumb it my answer
Turbo chef is not heating up, coming up on it
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Getting f3 mag current
f 3 means blown fuse , which is located on the right side of the unit at the bottom , third one accross, once you have tested the fuse and found it to be faulty, before replacing it , you have to find out why it has failed, there are several reasons why this has happen , 1/ if primary and secondary interlocking door microswitches on left side panel open before monitor door switch on the other side ,it will put a short accross L1 AND L2 blowing F3 fuse , 2/ CHECK high voltage transformers to see if there are signs of burning on either primary or secondary windings, if you are not a tech or a electrician it is very hard to explain how to test to the other componets, capacitor doide or magnetron visual inspections is all you can do
