20 Most Recent
Maxtor Shared Storage II N01R010 1 TB USB Hard Drive Questions & Answers
Trying to get my maxtor II to work with windows 07
Check Control Panel, System, Device Manager and make sure windows see's the connection. If you see a yellow triangle, that means the drivers are not correct. If you don't see it at all, that is a problem. Give Maxtor a call. You may need to update your motherboard bios, chipset drivers. At worst, you might have a problem with the motherboard or maxtor II device.
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
