20 Most Recent
SimpleTech 100GB SimpleDrive portable USB - black Hard Drive Questions & Answers
My external drive will not open on my new HP computer
Unplug the external. Then Try rebooting cold. When the computer stops +30 sec. Reboot the computer and plug the external when you see the HP splash screen.
- If that does not work, make sure you have the drivers for the ext. for your configuration. Win 8, 8.1?
- You can go to the site where your external was developed at and make sure you have latest drivers and if there is a problem associated with your device.
- On newer machines there is also 3.0 USB connections. While it should not make any major difference, make sure that your ext. is not plugged into a 3.0 USB. The 3.0 USB is blue in color.
Can SimpleTech runs on 220 voltage
Not enough info.....
Ask Simpletech. I Dont use simple tech brand but it usually is similar to other products.
Most Hard Drive Boxes are connected to a Power Pak that goes into the AC wall outlet to drop the power down to low DC voltage.
Most power pak's handle 110 & 220 ac these days. Read the tiny writing on the power pak label. It's usually marked as input & output.
Good Luck
Read only access
Right click on the file or folder, left on properties, left to remove the tick for Read only
