20 Most Recent
Seagate 160GB 3.5" External USB Drive 160 GB Hard Drive Questions & Answers
Accidentally i plug different adapter. It is not working now.
you might have fried the voltage regulator on the board chances are the hdd is okay its a sata or ide open housing and go to tiger direct and buy whichever style hdd it is adapter to usb i.e ide to usb or sata to usb ot a new enclosure like nexstar cx once you got it hooked up if its still good you can get to your files
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
I just upgraded my Windows Vista 64-bit computer
if you external hdd does not work on any other computer other than yours . try opening it with a linux OS. u can Ubuntu live cd .. boot from it and run it live...connect your HDD .. i hope you can see you files then >>> good luck
My external hdd segate 160
Try connecting this USB hard drive to another computer.
The clicking sound is known as the "click of death" the read write head is banging back and forth and is a sign the hard drive is faulty.
Ceedo file is corrupted how
Hi, Thanks for using fixya.
Go in My computer/ Computer with the 160 pluged into the usb port. Right click on the Seagate choose format If you have other files on it and you don't want them deleted go in safe mode and try to delete the file that way
Hope this helps.
Terry.
Cannot access / view hard
Try connecting it to a different USB port on your computer.
Try connecting it to a USB port on a different computer.
If the problem continues, then one of the two major components inside the enclosure:
* disk-drive
* USB-to-disk-drive adapter
have failed.
Open the enclosure, and remove the disk-drive, and connect it as a "slave" disk-drive in a desktop computer, to see if the disk-drive, by itself, still is accessible. If not, then you could buy a new disk-drive, and "transplant" it into the enclosure, to "resurrect" your external enclosure.
Is the disk-drive still under warranty? If so, contact Seagate, and exercise the warranty, to get a replacement.
3.5 inch external hard drive
Hello
My
apologies if this message finds you long after posting this problem ,
but I am currently working through a backlog of problems that never got
answered and hopefully this info can still be of use if not now possibly
in future.
Please download Disc Digger HERE.
This is a free tool you can use that works very well and there is no
installation required, just run the program once you downloaded it.
Once
you have connected the memory disk / hdd to the computer , run the program.
On
the program , select the dig deep option for accidentally deleted files
or dig deeper for a formatted drive. Then select the disk you want to do
the recovery on and run the program.
The data will be displayed
and you can recover it from there. This will only work if the card has
not been used since the data was lost. Save the files to a location
on the computer hard drive and not back to the disk it is recovering from as this will
overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Can not register product 160 GB external hard drive
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
- The USB cable between the drive and the computer may be damaged.
- The circuit board which connects your drive to the interface of the external may be blown.
- The power supply (if applicable) may have a blown transformer.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
