20 Most Recent Maxtor One-touch III Mini 40 GB USB 2.0 Hard Drive Questions & Answers
sure you can recover some files (not all) using third party recovery app. and do not write data to disk untill you complete the recovery
Maxtor One-touch... | Answered on Jul 17, 2017
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Maxtor One-touch... | Answered on May 18, 2010
with it connected open applications and select utilities and then go to disk utility, open that and when it is loaded the maxtor should be in the list, you need to erase it, this will install the apple operating info (it should read some sort of f.a.t. to start with) you will loose all of the information on it
Maxtor One-touch... | Answered on Dec 30, 2009
If it's hooked up correctly, you should see it as another drive in 'My Computer'..
Maxtor One-touch... | Answered on Dec 23, 2009
It is not recognized because it has not been "initialized". Need to go to the Maxtor support site and download the driver software that will initialize the drive. If you boot up windows with the drive plugged into a usb port, windows might just be able to search windows update for a driver or a small window may pop up and state that the drive has not been activated and would you like to open the activation wizard, click yes and follow the prompts.
Maxtor One-touch... | Answered on Nov 16, 2009
With pc turned off plug the USB drive into new PC and boot it up. Now on new pc it should auto detect and install the USB drive. Now goto Computer and you will see your USB drive there. Open that up now its as easy as copying anything you like and pasting to whever you want to keep it on new pc
Maxtor One-touch... | Answered on Nov 01, 2009
the hard disk interface could be broken, open the hard disk case and use it as an internal hard disk as a slave in a computer to save your data
Maxtor One-touch... | Answered on Oct 28, 2009
Nothing to do with the OS. First test it in another pc to make sure the problem is with the laptop and not with the drive -it might have just died.
Some drives need  more power to function than an laptop usb jack can provide. Make sure it's plugged in with the auxiliary power supply.
Maxtor One-touch... | Answered on Oct 07, 2009
The computer is shown the malfunction divce. I cannot opne the the driver
Maxtor One-touch... | Answered on Sep 13, 2009
Might try downloading the drivers directly from maxtor
Maxtor One-touch... | Answered on Jun 04, 2009
Go to Computer Management
Then click Disk Management
You Will find Your Portable HDD without Drive Letter
Just Right Click and Assign a Drive Letter...
Thats all...
Enjoy..
-Rajkumar
Maxtor One-touch... | Answered on May 19, 2009
there should be a sticker on one side of the drive that tells you which pins to put the jumper on, so use the master setting if its the only hard drive your using. if its not, use the slave setting
Maxtor One-touch... | Answered on May 02, 2009
throw it away and buy a new one....that the best solution i have
Maxtor One-touch... | Answered on Apr 25, 2009
The blinking light indicates something is happening to know open :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=1600
And check the power cord and try with the known good power cord.
You can check this :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4996&p_created=1194886713&p_sid=SzkLKr3j&p_accessibility=0&p_redirect=&p_lva=1600&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTg0LDE4NCZwX3Byb2RzPTQxMCw0MjEsNDYxLDQ2NSw1MDgmcF9jYXRzPSZwX3B2PTUuNTA4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1
Good Luck.
Live, Love, Laugh.
Maxtor One-touch... | Answered on Apr 04, 2009
Before runnning the backup please go ahead and run the check disk once..
chkdsk /f/r use this command on the command prompt
Maxtor One-touch... | Answered on Mar 16, 2009
hello
drag the files to your new harddrive.or can you describe your problem little more plz.
Maxtor One-touch... | Answered on Feb 23, 2009
Maxtor One-touch  III Mini 40 GB USB 2.0 Hard Drive Logo
41 questions posted
Top Maxtor Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Phil Whisenant
Phil Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Maxtor Computers & Internet
Most Popular Question
use maxtor111 apple macbook pro
  • Computers & Internet
