20 Most Recent
Biostar 945GZ-SE Micro Socket 775 Motherboard (945GZM775SE) Questions & Answers
I want bio-star motherboard service
Please call to this address. These are the BIOSTAR service centre.
Abacus Peripherals Pvt Ltd
106, 1St Floor,Mittal Chambers,2-2-51,M G Road, Secunderabad-500003
040-66382390
91 - 0 - 9391308746
I hope this helps to you...
Want a user manual
See if Biostar has one.Get onlineand got to www.google.com In the google search box type: "BiostarSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals on the site.
User manual (945GZM775SE) Mainboard
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manual on the site.
My mother board switch not
Dear there can be many reasons -> Faulty fan that can fail to cool your machine.> Faulty power supply.> It might happen your the power plug in from the case's power switch hooked up to the wrong pins of the motherboard.> You can if you are confident have a look on those parts and fix those pin again or better to look for a service center.
Sound driver
if your computer came with
a motherboard disk the sound drivers could be on it
click start control panel
sounds and audio volume advanced speakers select appropriate speakers or audio
you will find 3 drop down lists make the necessary adjustments there or
administrive tools computer management device manager sound video and game
controllers could be a yellow question mark? right click to re-install drivers
if
you dont have a motherboard disk you will need to download the sound drivers
hope this helps
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
I want softwear 945 micro
Hi, the Drivers for the Biostar Motherboard is available to download from the below mentioned link:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=79Please download all the Drivers listed on the page and make a backup by writing it in to a CD or DVD. Then, install the drivers in the computer. Restart the computer for every driver you install.
Please install the Driver one after the other instead of installing two or more installation at a time. Since it will slow the performance of the computer and may cause errors during the installation.
Hi my front USB r
maybe due to lose connections inside the case or can happen with USB driver problems (reinstall motherboard usb driver)
945 gz micro 775 se
HELLO,
WHAT IS THE EXACT PROBLEM WITH THE MOTHERBOARD,YOU CAN ALWAYS BUY CARDS AND FIX TO THE MOTHERBOARD,IF THE ONBOARD CHIP HAS A PROBLEM
Bios ok but hang when
Could be corrupt system files, are you able to try reinstalling on a different drive? (different drive so that your current drive is not wiped and kept as it is)
If the reinstallation works then you can transfer your files off the old drive or put it into a caddy to use as external storage to access your files.
Essentially if the PC gets as far as the windows logo or sign of windows booting then any problem from there onwards is usually software (like corrupt windows files)
System hang and ram
Dear friend,
According to my experience there is no one can repair RAM slot. if your all ram slot are dead, so you would be change your motherboard. other wise you can use your other slots.
JAIN_IT {INDIA}
No sound thru front socket
check in audio maneger
disable front panel detection
or check connecting cable in side tha cabinet which connect the motherboare and panel
Biostar 945gz turns off automatically
If it's turning off after several minutes and not immediately. It could be an issue with over heating.
It could be from block air flow or improper installation of heat sink or even thermal paste.
Start your computer and enter the Bios setup. Normally you will find a place that shows the current processor temp. Watch it. If it rises above the set temp for shut off you know you have some reconfiguring to do in regards to cooling.
Hope this helps, but if not after you try that repost with what you find.
No driver disc
All drivers for this motherboard can be found at the following link:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=79
I want to define motherboard
Open up the link below , go to their support section , type in the number of your motherboard and they should supply you with an installation manual
www.biostar.com
Sound problem
my pc have speeker but cannot give sound my speeker is ok. but some body ask me install soun driver where i solve this problem please help me
