click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or if you can see your usb but its not workingports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seatedif this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
59 questions posted
261 Questions
83 Questions
84 Questions
44 Questions
49 Questions
