20 Most Recent Acer Aspire 1642ZWLMi Notebook Questions & Answers
Where is the wifi button located to be able to turn the wireless function on as i have looked along the keyboard and cannot see it?
Try this - look at the image - there is a indicator switch (#5) for wifi. Press the button to enable, again to disable. 26033511-vjqmyedechw0emkgmpeknzv3-1-1.jpg
1/2/2016 1:04:03 AM • Acer Aspire... • Answered on Jan 02, 2016
Hi. I would like to install again windows XP Professional, but I have this PC 7 years AND I didn't get Windows XP WITH IT. i BOUTH FROM PC WORLD. Could you help me if I can use Microsoft windows prof
you should have got a disc with it.if not you might try backup and restore programe,you will find this in your control panel. or you can try your upgrade disc but you might find your windows xp number may not run with the upgrade.
4/5/2015 7:24:06 PM • Acer Aspire... • Answered on Apr 05, 2015
Hi. I have problem with my lap top Aspire 1642ZWLMi. I would like to install again windows XP Professional, but I have this PC 7 years. Could you help me if I can use Microsoft windows professional u
yes you can but it will need todo alot of updats,and iam not sure about this but i think windows xp does not do all the updates anymore,but i could be wrong,i have a pc tower thats ten years old and i put windows xp on that just the other day and all is well.
3/29/2015 9:06:23 PM • Acer Aspire... • Answered on Mar 29, 2015
My acer 1642WLMi has lost it's sound completely
Check the sound is not muted. (Click on speaker icon at the bottom right of your screen. Move the slider all the up with your mouse. Ensure the small box is cleared) Also, right click on computer on the start menu and select hardware tab, and open the device manager. Look for sound device and right click on that. Check the drivers are ok for the sound chip you have. You may go to the Acer website if you can, locate support for your model and download and install fresh drivers for your OS if they can be found. Reply here if you try that and don't know how. You may try an external speaker / headphones connected to appropriate socket on the back of your computer if it's a desktop. If you hear sound it might be that the internal speaker has gone wrong (does your computer give one beep when you turn it on ? this is telling you most things are ok including your sound system. Open a cmd window and type 'beep' the computer should beep I think) there are many other things it might be, and more if you don't have the as-purchased set-up, but that's enough for now 7.March.2015
3/7/2015 5:49:35 PM • Acer Aspire... • Answered on Mar 07, 2015
2answers
Battery- Will boot without battery, freezes with battery
It sounds like your computer's battery settings are messed up. First, check your battery settings. Perhaps they are somehow set to put your computer to sleep when battery power comes on. If that's not the problem, go to device manager, open batteries, and look at the properies of everything there to be sure all is working. If nothing appears wrong, update or replace the drivers from your manufacurer's website if available there. It looks like you have an Acer--I know thatthey have some battery recalls out. Let me know how it goes. If you are in warranty, get help from Acer: Acer's basic service availability period, 8:00 a.m. to 5:30 p.m. (CST), Monday through Friday. Acer Customer Service at (800) 816-2237. If you get someone who says to reintall everything instead of addressing your problem itself, demand to speak to a supervisor (this happened to me) who knows what's what.
BTW, Computer companies like to sell you expensive batteries. You must always remove your battery while you are plugged in, or you will greatly reduce its lifetime of about 300 or so full charges. Also, to break a new battery in properly, so thatit will take a full charge, charge it for at least 15 hours, then let it completely drain and recharge 3 times. (that's in your Acer manual.) let me know what happens.
12/1/2012 12:17:55 PM • Acer Aspire... • Answered on Dec 01, 2012
5answers
Acer Aspire 1640Z BIOS problem
Dear all,
I also posted this one under "Notebook Bios Problems" which might notbe the correct place. Anyway here it is for you to see and maybe youcan learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS shouldI use i.e. how do I know if I need the AT or UMA version - how toverify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started icon_sad.gif but later I was all smiles icon_biggrin.gif icon_biggrin.gif
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
4/13/2012 9:37:25 PM • Acer Aspire... • Answered on Apr 13, 2012
My epson printer nx420 starts to print but then
have you try to evaluate your paper?, sometimes when it feed your paper the printer dis-align it and cause the paper jamming during printer. Try 1 by 1 load of paper, if the problem still the same then try to load atleast 10pcs of paper. Just a thought hope it helps thanks.
9/19/2011 11:26:08 PM • Acer Aspire... • Answered on Sep 19, 2011
2answers
I forget password how solve
Don't worry. It's a simple procedure. When u start up the computer, press ctrl+alt+delete twice. Then in the password box that appears, type administrator in the username and hit enter. Once you are in the administrator account, hit start, then control panel, then users then your account. Now change the password. You will only lose your msn or saved passwords for sites that you have.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,
Sunny.
9/2/2011 9:08:24 AM • Acer Aspire... • Answered on Sep 02, 2011
No recovery disks, no recovery
have you tried to use the recovery menu in BIOS which can be accessed by typing Alt +F10 at bootup. I suppose you still need to be lucky enough to have the hidden partition X: available on the hard disk.
If not then it is back to ACER support and beg for a Recovery CD.
Good luck
9/1/2011 12:23:33 PM • Acer Aspire... • Answered on Sep 01, 2011
Acer aspire 1642 frozen mouse
Connect an external USB mouse to get at least the cursor to work, then download the latest touch pad drivers from Acer's site
Check that you have not disabled the mouse pad (FN and F7?)
If that fails, you may need to dismantle the laptop and check the small ribbon cable that connects the touch pad to the motherboard has not come adrift.
After that it looks like physical failure of the trackpad / touch pad assembly
7/18/2011 5:36:41 PM • Acer Aspire... • Answered on Jul 18, 2011
Acer aspire black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
7/18/2011 2:30:05 AM • Acer Aspire... • Answered on Jul 18, 2011
My Acer Aspire 5810TG does
Until you can locate the underlying cause of the problem (could be mechanical, or your particular battery power configuration settings), you can try this:
Open up a command prompt window (Start Menu > Accessories > System; or, Start Menu > Click "Run" > Type cmd in the box and press enter)
Once the command prompt session has opened, type "shutdown -s" (without the quotation marks) and press enter.
You should see a box pop up warning that shut down will occur in 30 seconds. After the countdown completes, your computer should begin the shutdown routine. This command works for restarting the computer as well, just change "-s" to "-r"
6/14/2011 5:41:39 AM • Acer Aspire... • Answered on Jun 14, 2011
Hooked up to TV but
u cant get sound from TV linked to PC.....as the PC's sound system use a RF connection...it does not have a amplifyer...the sound system travel in two formats....non-amplified and amplified....the sound sent from PC/Laptop it's already amplified...but the TV connector can receive only non-amplified signal(say from a DVD player, camcorder, music system etc)...it cant process the signal from PC/laptop......you can connect ordinary speakers ment for laptop to the sound out jack in the PC/laptop and use the TV to receive the video signal....from PC
hope this helps
Kris
3/1/2011 5:03:18 PM • Acer Aspire... • Answered on Mar 01, 2011
How can i remove the password of bios of Acer
Hi
You have to remove the CMOS battery located in your motherboard or you need to adjust the CMOS jumper of your laptop
2/22/2011 11:34:39 AM • Acer Aspire... • Answered on Feb 22, 2011
BIOS restore
To reset the BIOS to factory settings read the information from this link, disregard the first point as that applies only to bypassing the BIOS password, the other 3 solutions not only will reset the BIOS password but will also bring the BIOS to factory settings.
2/10/2011 10:11:06 AM • Acer Aspire... • Answered on Feb 10, 2011
I've lost drives on the
Hi correa_jas,
Based on your situation. I suggest trying the following steps:
1. Try to install the latest driver.
2. You can download the driver from here.
3. Select your operating system then go to Wireless LAN section.
4. After downloading install the driver and then restart your computer.
Hope it helps.
Thanksfor using FixYa
Bestregards,
Reyjoshua07
1/25/2011 9:57:52 PM • Acer Aspire... • Answered on Jan 25, 2011
Hi. I have an Acer
If Acer do not have them to download online, then Win7 is not supported and you will have to return to XP. Trying Vista drivers, if available, may work as they are very similar.
12/28/2010 8:53:32 PM • Acer Aspire... • Answered on Dec 28, 2010
I have deleted my launch
The ACER recovery disks have all the programs on them. you can insert the disk and restore any that you may have deleted.
If you don't have your disks, you can download the applications from ACER's web site.
12/26/2010 12:10:13 AM • Acer Aspire... • Answered on Dec 26, 2010
Monitor is continually going black.
Normal 0 You could have a back light problem. This could be caused by a faulty inverter rt a faulty CCFL lamp. Please click on this link to determine the fault and possible fix :-
10/14/2010 9:15:49 AM • Acer Aspire... • Answered on Oct 14, 2010
Acer Aspire 1642ZWLMi Notebook Logo
70 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire 1642 frozen mouse
  • Computers & Internet
