20 Most Recent
Amana MVH210W Microwave Oven Questions & Answers
Microwave works but doesn't heat food.
check if it heats through a different outlet by its self if not element is shot but if it works you need a better electrician unfortunately because you might have a new fire hazard with incorrect wiring but thats really only way to find out
I have a 3-year old
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
I am trying to remove an old Amana MICROWAVE over
I'm not positive on old Amanas, but some very old units slid out of the main case. The main case was installed and the cooking unit slid inside the case. There were two screws in front that released a connecting device at the rear. Check at the front top corners for a screw that may disconnect this. I have also seen extra screws added through the cabinet to the side, that shouldn't have been put there, that are screwed through the side of the main case. Good luck I am available this evening for further assistance, just let me know. Have a Merry Christmas.
I have an amana microwave 1994 model mvh210w.
You can download the owner's manual
here free.
If it needs work or a new charcoal filter, etc., you can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Amana RCS10TS control panel inoperative (no display)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiUw7318_L-AhX-GTQIHUoVBacQFnoECBIQAQ&url=https%3A%2F%2Fwww.repairclinic.com%2FRepairHelp%2FHow-To-Fix-A-Microwave%2F71-199--%2FAmana-Commercial-Microwave-Microwave-Display-Not-Working&usg=AOvVaw1_3-brehj_-McaojgE7G2S
Amana 10D microwave fan stays on, doesn't shut off until unit is unplugged and re-plugged.
If the fan in your Amana 10D microwave stays on and doesn't shut off until the unit is unplugged and re-plugged, there could be an issue with the fan motor or the control board. Here are some things to try:
1. Check to make sure the vent is clear and unobstructed. If the vent is blocked, it can cause the fan to stay on.
2. Check the fan motor. The fan motor is responsible for turning the fan on and off. If it is faulty, it can cause the fan to stay on continuously.
3. Check the control board. The control board is responsible for controlling the functions of the microwave, including the fan. If it is faulty, it can cause the fan to stay on or not function properly.
If none of these solutions fix the issue, it is possible that there is a problem with the microwave itself. In this case, it is recommended to contact a professional appliance repair service for further assistance.
