20 Most Recent Centon Electronics MP4-001 MP3 Player Questions & Answers
2answers
Only plays ten seconds of songs
I HAD A VISUAL LAND MP3 PLAYER. ONLY PLAYED FIRST 10 SECONDS OF SONG. IT IS SET TO INTRO. WHILE THE SONG IS PLAYING PUSH THE BUTTONS AND YOU WILL SEE THE OPTIONS COME UP. SONG HAS TO BE PLAYING. CHANGE FROM INTRO.
7/13/2012 11:35:40 AM • Centon... • Answered on Jul 13, 2012
I don't know how to put pictures and videos on
Audio, video and image files are copied/transferred to the MP3 player from a computer using the supplied USB cable that is connected to your computer.
Most MP3 players will support photo with these file formats, jpg, bmp and gif.
Check the specification of your MP3 player to determine thetype of video file format it uses. Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. Click on this link for instructions on converting videofiles for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
4/9/2011 6:47:13 AM • Centon... • Answered on Apr 09, 2011
0answers
0answers
How to turn on
There should be a power switch on along the right side of it (see pictures here)
If it still doesn't turn on, then it probably needs to be charged.
Plug it in to the wall adapter it came with and leave that plugged into a wall socket overnight.
Then using the power switch should work.
5/28/2010 4:59:32 PM • Centon... • Answered on May 28, 2010
My songs on my mp4 Missil gl-1502 plays and stops
The player must be on a intro mode.
5/26/2010 4:10:01 AM • Centon... • Answered on May 26, 2010
Music would not play
virus all around in it coz u dun safely remove it!@
3/19/2010 6:19:03 PM • Centon... • Answered on Mar 19, 2010
My mp3 player is not supported by Windowsxp
Any mp3 palyer or mp4 player can support windowns xp now. Trust it. You should find out the real problem.
1/30/2010 7:43:39 AM • Centon... • Answered on Jan 30, 2010
Broken Headphone Jack
Replacing it is expensive. However the player is bound to have some sort of usb port on it. You can buy some usb headphones for about £15 and use those.
7/7/2009 6:01:16 PM • Centon... • Answered on Jul 07, 2009
HOW CAN I GET THE
Try looking around at centon.com
4/28/2009 3:23:56 PM • Centon... • Answered on Apr 28, 2009
2answers
Need manual for moV.ox mp3
Please visit below mentioned link to download the manual:
Centon MOV•OX MP4 Manual
Thank you
1/23/2009 11:12:28 PM • Centon... • Answered on Jan 23, 2009
No instruction manual. Do you know where I can get one?
Go to centon.com.
9/22/2008 5:00:37 PM • Centon... • Answered on Sep 22, 2008
I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
Do this procedure for "voice" mode to delete voice recordings:
Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
1. In stop interface (FM without stop interface)
2. Short press "MODE" to enter stop submenu
3. Click "NEXT" or "PREV" to choose "single" or "all" files
4. Short press "MODE" to enter the Delete interface
5. Click "NEXT" to change "no" into "yes"
6. Short press MODE to confirm the delete prompt
"Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
-Tha Mp3 Doctor
5/29/2008 12:41:26 AM • Centon... • Answered on May 29, 2008
DISK ERROR WHEN I TRY TO USE MP3
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
5/29/2008 12:39:56 AM • Centon... • Answered on May 29, 2008
0answers
Jamm mp3 player 2gb
Be the first to answer 2/27/2014 7:15:10 AM • Centon... • Posted on Feb 27, 2014Be the first to answer
I need a driver for my mp3 centon 8Gb
could not locate the CENTON specific driverclick start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driverhope it helps you
4/3/2012 7:01:48 PM • Centon... • Answered on Apr 03, 2012
0answers
Can't get Centon 4GB MP3 player to play
Press "down" the forward-revers bar to enter to the sub-menu
1/21/2010 10:03:37 PM • Centon... • Answered on Jan 21, 2010
Centon Electronics MP4-001 MP3 Player Logo
30 questions posted
Top Centon Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Centon Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Centon Electronics Audio Players & Recorders
Most Popular Question
only plays ten seconds songs
  • Audio Players & Recorders
