20 Most Recent Philips 42PFL5332D 42 in. LCD Television Questions & Answers
Are you sure the board you received is good?...you should have bought the board from shopjimmy, then they would have worked with your fixing your set.
Philips... | Answered on Feb 07, 2018
This sounds like a control board (i.e. capacitors dead or bulging/dying) or a ribbon cable problem. A service technician should look at this, however if you're handy you can open the back of your tv and look for loose or bulging/leaking/dead capacitors. Capacitors can usually be de-soldered from the control board and replaced with a similiar cap, but unsure about the ribbon cable. You might try to remove and re-seat the cable if when you press on it the line goes away.
Philips... | Answered on Sep 04, 2017
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Philips... | Answered on Jul 17, 2017
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Philips... | Answered on Dec 12, 2016
The T-CON board it is dying too.Must be replaced too.This T-CON board sit at the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Philips... | Answered on May 04, 2016
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Philips... | Answered on Aug 26, 2015
http://www.shopjimmy.com/philips-996500042146-power-supply-unit.htm That is the most likely cause of your problem.
Philips... | Answered on Aug 25, 2015
Hello
[1] Press the green color button on your remote control to enter the Settings assistant menu.
[2] Select your Location with the cursor up/down and press the green color button.
If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings.
Press the green color button again to proceed.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
[4] Press the green color button to each time confirm your selection and to jump to the following screen.
The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
[5] Press the green color button once to store all the settings and to return to the TV installation menu.
Note: When you skip or stop the Settings Assistant, then the Standard settings
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
Philips... | Answered on Jan 11, 2015
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Philips... | Answered on Jan 09, 2015
Check all the flat cables that goes from its T'Con to display panel for loose contact. Re-set it at both ends once and check. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Philips... | Answered on Nov 02, 2014
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
Philips... | Answered on Jun 23, 2014
Yes,
When 1 HDMI port is broken most of the time all the ports are defect. This is because all the 3 HDMI ports are connected to 1 multiplexer IC. Only when the connector or the copper connection on the board is damaged the other two ports still be functional.
You still can use the other connections ( not HDMI) the should be working.
Regards GJ
Philips... | Answered on Jun 17, 2014
try setup menu.
Philips... | Answered on May 26, 2014
This problem is most of the time an defect of the inverters.
You can use a repair-kit or replace the circuit boards.
INVERTER BOARD NUMBERS REPAIR KIT NUMBER
Master - 6632L-0470A PNEL-T707A KIT63
Slave - 6632L-0471A PNEL-T708A KIT63
As used on the LG / PHILIPS LCD PANEL TYPE: LC420WU5
Examples of models that use this panel:
• PHILIPS 42PFL7662
• PHILIPS 42PFL9900D10
• PHILIPS 42PFL5332D
• PHILIPS 42PFL7332D37
• PHILIPS42MF337B/37
You can find the parts by Ebay e.g.
Philips... | Answered on Apr 04, 2014
Philips 42PFL5332D 42 in. LCD Television Logo
271 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv will not turn makes going clicking
  • Televison & Video
