20 Most Recent
Soyo MT-SYTPT3218AB 32 in. LCD Television Questions & Answers
When I turn my TV on It displays but really dim
This problems is the causes by the board that call the T-CON decoders board,this board sit at the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
12/15/2010 1:02:10 AM •
Soyo...
Answered
on Dec 15, 2010
How do you set up
Yes, your TV is cable ready. To set up, you will need to use the original remote and complete the following steps.
1. Connect your cable box to your TV using either antenna (RF) cable or component A/V
2. Press the "MENU" button on your remote
3. Select "CHANNELS" using the up/down arrow buttons on your remote and press "OK"
4. Select "SCAN CHANNEL" and press"OK".
5. Select "CABLE" as the source and press "OK" to tune
The TV should now automatically tune the cable stations and exit the menu. If you need to exit the menu and/or start again just press "MENU" on the remote again.
If you have no picture, press the "INPUT" button on your remote repeatedly until the input is on "TUNER" if you are using an RF cable or "COMPONENT" if you are using component A/V cable.
Your TV should now be setup for watching cable.
Please post back if you need further assistance.
Regards,
BElectric
12/5/2010 3:59:13 AM •
Soyo...
Answered
on Dec 05, 2010
Tv wont turn on
I have the same problem. I took off the back panel and the power circuit board was fired. You can see burnt brown marks on the components and the circuit board. I did a google search and I can get a new power circuit board for around $55. Very easy to install.
9/24/2010 2:43:09 PM •
Soyo...
Answered
on Sep 24, 2010
My Soyo 32 the problem start on the right side
kind of sounds like a panel problem, t-con brd which is usually only available with the panel anyways. panel is pretty typically more expensive than the tv is worth(if its even available). you might be able to search around and find a service center that has a free estimate take a look at it. other possibility is the main brd
3/18/2010 7:59:50 PM •
Soyo...
Answered
on Mar 18, 2010
