20 Most Recent
LG 32LP1DC 32 in. HDTV LCD Questions & Answers
My television is freezing
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Blown Fuse LG LCD
Unplug tv and let it set for a couple of hours. Remove the back panel, the fuse is located somewhere near where the power chord comes in. Remove fuse and replace with one of the same rating.
What does a blown tv capacitor look like?
The tops will be puffed up on top often they will leak from the tops . I am attaching a pic of some bad capacitors. they should be completely flat on top any puffing up on top indicates a bad cap and it will need replacement
When I power up my LG LCD TV the power light
Hi,my name is John. Welcome to FixYa. Its going in to protection standby mode. Something in the high voltage is shutting it down. Try to unplug it , wait 30 minutes and try it again. Thanks for Choosing FixYa....John
Power wont turn on but the red staus light is on
Does the light blink? If so, count the blinks. Those are error codes for the TV. Turn it off and unplug it... then plug it back in and try to turn it on and check to see if it blinks and count the number of blinks. It should blink "X" amount of times... then a pause... then do it again... several times.
Original problem: Flashing red
Hello Swcann, hi, the replacement of the power supply board was the right way to go but misses out one very important thing. "Why did the power supply board at the first place, failed?", check the main board for failing parts such as a shorted diode, leaking capacitors, loose screws or overheating ICs. Or better check for a new main board.
LG 32LP1D, 32" LCD TV
Replace the CPU fan it is bad. Also CK boards for bad capacitors that are swollen or puffed up on top. 220uf 25v- 330uf 10v 1000uf 16volts.
You can also google to this website Encompass Parts Distrubtion
type in model number they should listed parts in stock as well as price
and Part numbers.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
