20 Most Recent
Sharp LC-52D62U 52 in. LCD HDTV Questions & Answers
Sharp aquos tv opc and power led flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Replace screen
Well, sir, you can't. Not unless you know someone, SHARP does not deal to any store or supplier with replacement screens. Besides, the replacement screen, which would include a new LCD panel, control board, plastic screen cover and the like would probably cost more than a new TV in the market.
1/4 of my sharp aqous
This lines are in colors or black vertical lining in shaping?Yes?These lines are not causes by u or causes by an object by using forces hitting the LCD screen panel itself to causes these problems?Yes than the LCD screen panel are dying and leaking radiation can't be repair only by replacing new LCD screen panel not worth replacing and reparing if require a new LCD screen panel only.If these vertical lines are in colors or black are showing up and causes by the tv itself?Yes.Than the tv have a dying board that call the T-CON board and this board only job are docoding any pictures pixels before it showing up to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjmmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
I have a Sharp 52in model LC52D62U.The (on) light
yes , the problem on ur tv is the main signal board , when this board goes bad the opc light blinks , i have fix like 20 tv with this problem , now to order the right board u most look at tuner inside ur tv and get a 4 digic number follow by word main , by replacing this board would fix this problem on ur tv
No audio suddenly
It possible but unlikely that your speakers are bad. First what you want to do is try to see if its not the source. IE cable, dvd, bd or video game. Try replacing wires.
If that fails, (Depending on the set) replace main board. If its a slightly older set main and terminal. I don't have access to sharps website at this moment to see the exploded view of this set.
