20 Most Recent
Toshiba Qosmio G35-AV650 Notebook Questions & Answers
Toshiba Qosmio G35-AV650 won't power on...at all. Power button?
No! the power button is the last thing you would expect to go. Remove main battery and try again, if no! sub out the ram one at a time and test each one by attempting to power up, if still no result! the DC jack in the laptop is a trouble spot, at this point dis-assembly down to the motherboard is required, check DC jack connections carefully and resolder anyway, "board is double foiled"
Qosmio G35 full restore
The recovery disk provided when purchased are FAIL. You have to purchase working disk from Toshiba for 30.00 plus shipping. I think this is bogus but they won't budge.
My video card on a Toshiba Qosmio 35-av650 is
no changing video card does not affect in hibernating or standby. go to control panel and check if your standby and hibernation options are activated and if they are then you should make some space on your c drive because hibernation property requires 1gb of free disk space
I have a Qosmio G35 (as stated) and I
Most of this series already came with a core 2 duo
However to get best use of that you do need to make sure you install a 64 bit OS
It will go up a small amount in CPU speed but that increase will be negligable in the grand scheme of things.
4Gb ram is sufficiebt to run windows 7 but the limiting factor will be the graphics.
The problem with almost all laptops is in most cases the inablility to install a decent graphics card of suitable power to take advantage.
If you want to use it for gaming of any proportion then you would need to consider a new laptop.
If gaming is not a major concern then it should be suitable for the 2 years you are seeking to achieve.
Any additions including extra memory bring about increases in heat.
For sure you should get a proper cooling pad with its own power supply. Dont cheap out on a laptop usb powered cooler as you fill find battery drain heavy and even possible burn out of the USB ports.
Again doing a cpu upgrade is not going to give you as much benefit as you would like and from my POV the cost would outweegh the benefit.
Same Video garbage on screen and external monitor
On a laptop, the video card is part of the mainboard, not cost efectively replaceable. If there is video garbage on the screen, looks like a new computer unless you want to disassemble it to see if there is a loose connection between the display and the mainboard.
Display adapter fail
i use a
Looks like you have become a victim to the Video Burnout plaguing this series of notebook, I had the same issue, when Toshiba replaced the board it worked for about 3 more months then quit again. (this time outside the warranty) I'm looking for another working board to replace mine with. Good luck! it is cheaper at this point to replace the puter.
Screen freezes,cannot click on anything although I
It may be Processors Time is critical. Anything programm run and complete more resources.
1. Run TaskManager, amd see your process. Find this programm, and kill her process, or her tree process.
May be viruses, or mailware...
2. Your PC its very hot: Clean cooller by procesor.
3. HardDisk is freeze system. May be, make one's appearance "bad blocks".
How to activate the DUAL MODE PAD ?
Go to Control panel > mouse properties >Device settings>Settings>
Now the properties of LuxPad Windows appears
in the left side of the windows select Tapping > Dual Mod > Switch to Bottom mode by tapping in the upper right corner
Hope this helps
Siju.D
My Toshiba has a finger recognition unit on it. It
Try booting up in safe mode (tap F5 as the computer starts up until you get the black screen with white text and select Safe Mode).
Log in as Administrator. With any luck you will have no password for the Administrator account.
Go to Start->Run
type CMD and hit enter
You'll be at a command prompt. Substituting your user name for <username> and a new password for <password> type in
net user <username> <password>
Now your password has been changed. Reboot into Windows and log in.
Worked semi-ok for one year now a daily babysitting nightmare
There is malicous code running in the computer. Goto: Start, Run, Msconfig, and click Start up Items and disable everything and then apply the changes and restart the computer and allow it to run if everything works fine then you know it is in the start u items and i would recomend using Hijack this to remove the regestery entrys.
