20 Most Recent
Sharp LC-20DV20U 20 in. LCD HDTV/DVD Combo Questions & Answers
DVD Displays "Incorrect Disc"
Movies and CD's that I've played before in the Sharp now read " Incorrect Disc" . Is this fixableby me or do I have to take it in for service? Thanks.
Dear sir
before,i use to watch
Please make sure the silver side of the discs are nice and clean, if they are smeared with fingerprints the laser pickup may not be able to read them properly, I usually clean my discs with warm soapy water and dry them gently with a soft cloth.
If thats not your problem or it doesn't work then it's likely the laser pickup/module needs replacement.
Hope this helps.
There is no power to the television when plugged
As with all thin screen televisions the most common problems develop in the internal power supply that requires a shop for repair. There is also a possibility that the remote is not working. Try turning it on from the front panel. Solutions to that are try replacing the batteries in the remote.
There is also circuitry in the power supply which will shut it down if a defect is detected. That would be a shop repair also. You have already bravely taken the first step by making sure it's plugged in. Always the first thing you should think of.
