20 Most Recent Casio EXILIM Card EX-S770 Digital Camera Questions & Answers
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Casio EXILIM ... | Answered on Mar 07, 2019
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Casio EXILIM ... | Answered on Dec 25, 2014
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Casio EXILIM ... | Answered on Jul 24, 2014
See the main menu options cam and play back select the option from the menu
Casio EXILIM ... | Answered on Jun 12, 2014
I don't understand. Did you buy several new batteries, and they are all bad? Or did you use the same battery, after you charged it?
I fyou have a mulit meter and know how to use it, you could easy measure if the battery is still good.
Try to connect with the small contacts on the battery, and measure the voltage of the battery. It should be a little over 3,7 volt, That is the voltage needed in the camera. But without any load the voltage is a bit (few tenths of a volt) above the voltage printed on the battery. If it is ono a few tenths lower, the battery is defect.
Buying batteries for elder camera's can be risky, because you never know how long they were in stock. You are only lucky, when a manufacture uses the same battery in newer models again. so buying a lot of old batteries brings you no where.
Casio EXILIM ... | Answered on Nov 23, 2013
I have had success with this camera photo recovery software called asoftech photo recovery... Download the program
Digital Photo Recovery Software
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Here'a good tutorial that you can take a look
Recover deleted photos from camera
Casio EXILIM ... | Answered on Feb 25, 2013
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Casio EXILIM ... | Answered on Jan 28, 2013
Follow the instructions on pages 10-11 of this manual.
Casio EXILIM ... | Answered on Jan 18, 2013
Follow the instructions on page 184 of this manual to copy the pictures to a card, then download normally from the card.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Try the procedures in this tip.
Casio EXILIM  Card EX-S770 Digital Camera Logo
285 questions posted
Top Casio Cameras Experts
Ekse
Parshiv Luthra
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
accidentally deleting all picture files
  • Cameras
