20 Most Recent
HP iPAQ rx5915 Questions & Answers
Touchscreen not reacting to stylus but the buttons
- urn on your HP iPAQ Pocket PC.
Use your stylus to tap on the "Start" menu.
Tap on the "System" tab.
Tap the "Screen" icon.
Tap the "Align Screen" button.
Tap the center of the cross-hair object carefully at each
location as it moves around the screen.
Tap "OK" to complete the screen alignment.
HP iPAQ rx 5915 will not turn on
seems like you have a problem with your charger.happened to me too.did you try charging the ipaq via the usb cable on your computer?
Just a general question
What maps it comes with depends on where you buy it. I have an Australian version which includes maps for all of Australia and works fine. Tom Tom update the maps periodically but an update is about A$150. It will also work with any other Tom Tom maps you have.
Won't sync from iPAQ to PC
Sounds like you've got the ActiveSync setting for the Calendar set to one-way from computer to PDA, not Synchronise, which means the computer will always over-write anything it finds on the PDA that isn't in the computer. Try uninstalling/reinstalling ActiveSync, and pay particular attention to all the settings when you reconnect the PDA and it sets up the connection - from memory at this point you can define the "direction" of synchronisation.
Tom Tom navagation files out of place
Try putting the files like this:
In My Device/iPAQ File Store/iPAQ GPS, put the folder with your country name (in my case it says Australia), the "Navigator" folder and the "GPS" and "Map ID" files.
In My Device/My Documents/Tom Tom you should have a file thats called something like "Australia-3bc66a12" (will be different for other countries), and another called "TTToday" and any POI files you've created.
See how that goes. Otherwise, you may be able to reinstall TomTom software from the original disk if you have it. Any map upgrades you've bought will need to be reloaded from TomTom Home
Tom tom one cant find signal.
First checkpoint is the internal antenna - you can check this by getting hold of an external one (they're about AUS$20 off the net, make sure its got a MMCX connector). If that works, the internal antenna is detached/failed. This may be beyond a home remedy and require HP repair (or just settle for using the external antenna).
HPiPAQrx5915 wont active sync with pc or laptop by usb or bltooth
What version of ActiveSync are you using? Open ActiveSync on the PC, then open "About ActiveSync" under the "Help" menu - it should be version 4.5. If not, download version 4.5 from Microsoft as a first attempt to fix the problem. If you are using 4.5, try uninstalling/reinstalling again but make sure you do a soft reset (push the pin on the top of the device) before you connect the Ipaq. If this doesn't work let me know and we'll try some other things.
I bought a HP iPAQ
retrun it, cancel your credit card, go to paypal and they can resolve it.
How do you hard reset
. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until
the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the
Reset button.
The HP iPAQ restarts and powers on
Rx5915
I got this info from HP website..
1. Press and hold the Quick Launch and Rotate Screen buttons.
Reset button.
It doesn't mention a password. I also have an HP Ipaq and don't need a password to hard reset. Good luck. If this helps you plz rate this. Thank you kindly.
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
