20 Most Recent
LG L1932TQ LCD Monitor Questions & Answers
No power
1. Check whether power is there
2. Check the power sockets receives the power supply
3. Check the Female socket on power chord is fix with male socket on monitor
4. Check the power chord is leak free.
No picture
My model no is 42LV3400 BTMYLJT and serial no is 111THQL00668.and expire date is 24-02-2013.thi is running Ok. but yesterday tv is running after tv screen is OFF. but sound is OK.
The unit is about 5 years old and will no longer
More likely will need a good set of new caps, abouit $15 for a kit.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
The screen goes blank while
It does the same with another PC?
If it is the monitor problem, more likely to be bad caps, that will be the first thing to look for first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Monitor was working fine. Plugged monitor into
This tells me something is out of sync with the machine now.
What version of Windows are you running on the computer? Let me know and I will tell you how to fix this problem.
Just reply to my answer here and I can help.
Thanks
Tim
No Power
First place to check will be the power supply section, check the main AC fuse first, then look for caps with bulging top or leaking liquid. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps:
http://s807.photobucket.com/home/budm/allalbums
No power, is it worth fixing?
The proper answer to your question is "it depends".
- LCD's have a long operating life compared to Plasma but they will burn out eventually. If this monitor has been used extensively then even having it fixed will not be worth it because the panel may die off in just a few months
- However, if the LCD was seldom used, then it may be worth it to fix it
- LCD panels are also known to be very expensive. If your problem is just electrical then it will probably worth fixing it.
- However, if your problem is with the panel itself, then replacing it is a better alternative because the replacement panel is very expensive and will be almost as much as a new unit.
NOTE: Please rate our help to keep this free service online.
LG L1932TQ monitor wont turn on
This could easily mean your monitor has blown , or been destroyed by maybe a power surge or power trip , if it has a warranty return too shop , and they should replace it
Thanks
I shut down my computer at night. When I come
that blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
My monitors on off button is just flashing on and
You need to check on the input source. Double check if its powered on. If it is, check the cable connections and see if the connectors are fitted properly. If this is presumably connected to your computer, check the video card. It could be a faulty video card issue as well.
When I start up, the monitor flashes on, and sometimes
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is usually caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site
www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.comOver 21 years of computer and printer support/repair
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
