20 Most Recent Mackie SWA1501 Subwoofer Questions & Answers
How to open my mackie swa 1501 subwoofer to change the fuse?
Service manual is available for free from https://www.manualslib.com it contains disassembly instructions. If you change the fuse and it blows again, then your amp will need service.
12/13/2017 3:06:08 PM • Mackie SWA1501... • Answered on Dec 13, 2017
0answers
Why does it randomly lose power?
Hello, I can not say what the direct cause is, perhaps some soldering points on the printed circuit bords are loosen due to thermic stress. test: give mechanical ticks on the woofer while he is playing to check this. Hope you will have succes.
6/11/2015 7:55:01 PM • Mackie SWA1501... • Answered on Jun 11, 2015
Where can I get a replacement Mackie SRS1501 Motherboard?
Cotact the manufacturers for local distributors.
1/12/2015 6:12:54 PM • Mackie SWA1501... • Answered on Jan 12, 2015
No power give me a soluition
check to see if your fuse is good usually on the back panelwhatever it takes you have to find out if there fuses good or not
10/10/2014 1:07:17 PM • Mackie SWA1501... • Answered on Oct 10, 2014
My mackie swa 1501 when you plug in no power checked the outlet their is power checked power cord good. what can i do
There are many possibilities, the switch, motherboard, electronics etc. If you are a DIY kind of person and you want to try trouble shooting yourself, you need tools. Better still, take it to a service person/ outlet to proper checks.
10/6/2014 6:21:36 AM • Mackie SWA1501... • Answered on Oct 06, 2014
Thermal light on very low sound?
Well , have you checked that it's screwed on tightly , and no other gear is burned, especially your transformer and rectifier or a simple diode. With these things it's not u a huge search way , since it often comes out that your main power supply is broken, even it gives the right output voltages without a load. THE SAME COUNTS FOR OLD CAPACITORS WHEN YOU MEASURE THE WITH A NORMAL LCR METRE, until the load comes on it andvthe speed and capacitance drops like a two sizes two large, frozen underwear.... jHavebyou ever opend one? , you need often to cut a tight wrap, so have a sharp cutter at hand and to avoid damage to the outside of your unit, tape it with papertape, and not the gray strong tape . Unwrap the cables , since theyre often wrapped, to your speakerunit and see what's happening and feel what's getting that hot. But first a look at the unit, since it also can be one capacitor is blown.... take a good look.I searched and searched and after days i say two burned black tiny caps.......
9/10/2014 5:09:47 PM • Mackie SWA1501... • Answered on Sep 10, 2014
2answers
Thermal Light it turns on everytime i turn on my Sub.
One major question, about what does aftervtwo minutes the state of your system is( without using music) and is it connected still tight, does yourvamp start working?, thx richard
9/10/2014 7:04:27 AM • Mackie SWA1501... • Answered on Sep 10, 2014
Why does my mackie swa 1501 sound keeps cutting in and out
So it's heavy? .... i wanna know exactly what happens . You turn it on and turn on the volume, pls tell mecwhat exactly happens and when with which freq thx rich
8/15/2014 8:34:20 PM • Mackie SWA1501... • Answered on Aug 15, 2014
2answers
My 3 year old daughter poked a hole in the middle of my mackie hr824 subwoofers! how can I fix? I believe they do not make this model anymore! Please help [email protected]
Try Parts Express; they have a speaker repair service. http://www.parts-express.com/speakerrepaircenter
7/17/2014 5:56:17 AM • Mackie SWA1501... • Answered on Jul 17, 2014
Can I replacement the woofer on a swa1501 with any woofer
Yes, with the appropriate replacement driver in size and similar specs regardless of the brand. P-audio drivers worked fine in this unit.
12/3/2013 9:25:43 PM • Mackie SWA1501... • Answered on Dec 03, 2013
Huge popping noises intermittantly at low
Does it still make the noise if all inputs are disconnected? ...to try and determine if it is internal or externally caused...
8/27/2013 6:14:58 AM • Mackie SWA1501... • Answered on Aug 27, 2013
What fuse to use?
AC125V-T6.3A
4/24/2013 1:40:46 PM • Mackie SWA1501... • Answered on Apr 24, 2013
Mackie SWA1501 Subwoofer Logo
88 questions posted
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mackie Audio Players & Recorders
Most Popular Question
fuse use
  • Audio Players & Recorders
