20 Most Recent
Xerox Phaser 6250 Laser Printer Questions & Answers
How do you use photo paper in a xerox phaser 6250?
If you want to use photo paper for your Xerox phaser make sure the photo paper is meant to be used in your printer. The best paper would be the Xerox brand photo paper which is made to be used in the Xerox phaser printers. You use them like normal paper and print your document or image onto the paper. If you cannot find the paper that works with this xerox printer go to the Xerox website and under supplies, then entering your printer model it will give a list to the paper recommended for this model.
How do you reset transfer roller count on phaser
I have a XEROX 6200 Printer. I tried to do the solutions above, but I
did not have those options in the Maintenance Menu. I pulled out the
Transfer Roller Unit and opened up the two screws on top. When I pulled
the top, it was loaded with toner. I poured out all that toner in the
trash and blew out the rest with a air gun till it was clean. Be careful
of the two white gears on the side, when you take off the top. You
don't want to lose them. Anyhow, I reassembled the unit back and stuck
it back into the printer and the error message was gone. Yeayyyyyyyyy!
Phaser 6250 colour printer won't print blue -
Big problems here, sorry, suspect the magenta might be at the root of your problem.
as your problem was listed 2009 I suspect you might have sorted your problem by now.
Good luck.
What is wrong with my printer
I get this many times but I always see the paper jammed when I open it up. Once I removed the sheet which seems to stop at the transfer roller, I restart but it sometimes happens again.
One has to check the paper in the tray and see if it is free inside the top of the tray.I move the pickup.
Have you turned it off for a few mins then on again. Tried different paper?
Good luck
I have been receiving two
What it is saying is the image drum needs replacing. That is a separate part on this printer. You just need to get one from Xerox.
It will pop in almost as easy as the toner cartridge. After your print quality should improve a lot. If you look at a page now you may see little specks of toner scattered on the page or rougher edges on things. A new image drum will get rid of all of that.
Keep getting the error message
Welcome to FixYa.
This error message means that you already have reached the 15,000 prints and the transfer roller needs to be replaced.
In some cases you can reset the transfer roller from the printers control panel. Try this:
- Go to the Menu MAP (Main Menu)
- Go to Supplies Info
- Scroll and look for Transfer Roller Reset
- If it does not have one, Go to Transfer roller life and see if it has a reset option.
If it does not have one, you need to replace the transfer roller.
Thank you for using Fixya.
Jas247
I have a Phaser 6250.
Hi jewaddick,
If your printer wont print from the bottom tray, it is often caused by a broken switch. Please check to see if the switch in the printer is not broken. Just take the tray out and look inside, you will see a switch assembly that corresponds to the printer tray setting. Also, please look at the paper sensor and see if it swings properly. If you will need to get a part, 116134300 1 SWITCH; PAPER SIZE ASSEMBLY. Here are additional troubleshooting that you may apply on this concern.
1. Unplug the Phaser 6250 usb and power cable. Wait for 30 seconds and plug both cables back in. Press the devices power button and try to print again to see if power cycling resolved the problem.
2. Try to uninstall and reinstall the driver if there is still a problem.
Hope it helps.
Thank you for using FixYa.
