20 Most Recent
Sceptre Komodo X37SV 37 in. LCD Television Questions & Answers
Blue light blinks will not turn on
chances are a capacitor is blown on your psb.have a look for buldging caps,its a plauge for these tvs.replace with like kind,very cheap to buy from maplins and the like,will require soldering and basic skills
The picture on my screen is not stable. It comes
Usually i would suggest you use the tracking feature if it were to be from only one input but since you have tried various inputs then this problem seems peculiar. Try to examine your user manual there should be some feature used to fine tune the picture quality which is being produced on the TV screen usually the adjustment should be more like fine tuning a station this should help regulate the picture.
On the other hand if you can get replacement cables for the connection as the cables could also be a cause of the problem.
Hope this solution has been helpful?
The blue power light just binks
Check the power supply board for those dead capacitors.It alway have bulges up on it tops or puff up on it tops.Replaced those dead gases leakages capacitors.Than,it is the power supply board it dead power supply board.No,capacitors bulges up on it tops or puff up on it tops.The logic Tuner board is dead.
I have a DVD that is stuck in the player, the eject button does not release it. Help!
You'll have to take the cover off. This only consists of a few screws to remove, and lifting off the cover. When you have the cover off, try turning any white gears (carefully) to open the drawer. Some tray mechanisms have bad design. They refuse to open after a few months. This is in the design of the plastic parts and mechanisms of the cd drawer. Flawed design.
12/17/2022 2:56:15 AM •
Sceptre...
Answered
on Dec 17, 2022
How to connect laptop to Sceptre TV
HDMI Connection
- Connect one end of the HDMI cable to the laptop VGA port.
- Connect the other end of the HDMI cable to one of the HDMI connections on the rear of the TV.
- Connect a separate audio cable between the headphone or speaker output on the laptop and the audio in connector on the TV.
9/13/2022 3:39:27 PM •
Sceptre...
Answered
on Sep 13, 2022
Sceptre hktv83ac black screen no image
A lot of people miss understand how the backlight circuit in the power supply works, you will get voltage testing to ground as its the B- side that's switched, the chassis ground and backlight B- are not connected. If you tested each LED strip and they're all good there has to be something else going on other than the typical backlight issue we see on so many LED sets.. I'm not an authorized service center for this brand TV so I don't have a service manual, if this set has separate power board and main test the bl_on pin on the power supply, you should have around 3.5 volts there, that's what tells the back light section of the power supply to turn on.If you don't then it's a bad main board
8/12/2021 7:26:33 PM •
Sceptre...
Answered
on Aug 12, 2021
Trying to program direct tv remote to sceptre tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
7/25/2021 2:32:50 PM •
Sceptre...
Answered
on Jul 25, 2021
