20 Most Recent Brother MFC-3360C All-In-One InkJet Printer Questions & Answers
How to remove error initial 48 in mfc j220 printer brother?
it shows that unable to print50. or remove paper jam at the back. but nothing is in..how can i resolve this problem
8/1/2021 7:18:18 AM • Brother... • Answered on Aug 01, 2021
2answers
What plug i use to print to MFC3360C. mISSING PLUG
Sir/Madam You Do Not Need To Use any Plug all You need To Install Right Brother Printer Driver For Your Brother Printer Problems,From official Brother Printer Driver Website, Or If You Still Having Brother Printer Problem Then Follow Us For On: Brother Printer Support
9/29/2018 11:26:24 AM • Brother... • Answered on Sep 29, 2018
While printing documents in black, every few (10) lines would come out faint.
Hi Noemi: Is is possible that the cartridge needs replacement?
5/1/2015 9:14:58 PM • Brother... • Answered on May 01, 2015
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
4/14/2015 5:38:01 AM • Brother... • Answered on Apr 14, 2015
What to do when there is unable to init 48 in brother printer?
I am a Brother employee working for the software technical support department. We have a solution for your issue posted on our solution site. http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000006900 Description of Problem 100000005675 How do I clear the message "Init Unable" (followed by a two character code) from the display? Brother Software Technical Support http://www.brother-usa.com Frequently Asked Questions
6/30/2014 8:54:07 PM • Brother... • Answered on Jun 30, 2014
I am missing the plug to connect the printer to Laptop. I need to know what to purchase.
Sir/Madam If You Having Problem In Your Brother Printer Connecting To Your Laptop then You Do Not Need To Purchase any Thing,Make sure You Have Bluetooth And WiFi In Your Laptop and Necessary Brother Printer Drivers, Otherwise Please Download Brother Printer Driver From Official Brother Printer Website, Or In Case You Having Still Problems Then Follow Us For On: Brother Printer Support
1/23/2014 9:38:42 PM • Brother... • Answered on Jan 23, 2014
Brother printer MFC-3360c working for years now it
Most likely the soldered-on fuse on the circuit board has blown. Check online for information on how to replace this or contact Brother Support for instructions. I have found that the prices on the replacement parts through the manufacturer is very price competitive and their staff helpful.
10/23/2013 5:04:10 AM • Brother... • Answered on Oct 23, 2013
2answers
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
10/14/2013 11:28:14 AM • Brother... • Answered on Oct 14, 2013
My Brother MFC-3360C has worked perfectly until I
First I will have to recommend that you leave the unit connected directly into your computer rather then through the USB hub.
You will also want to reset the printer.
1. Turn the power off by unplugging the cable. 2. Hold down the Menu button 3. Plug the power back in while holding menu 4 You should see "maintenance" on the screen; if you do not repeat steps 1-3. 5. Press 0 1 6. Once you return to Maintenance, press 9 9
If this still does not work you will want to uninstall and reinstall the software.
Thanks,
Pat
1/21/2013 3:12:59 PM • Brother... • Answered on Jan 21, 2013
2answers
Black cartiage is not working
Sir,
Check the black cartridge it will refill or not? open the black cartridge and shake it and reinsert. Check with printer options, if any option selected with color only uncheck it and select the best quality option.
Thanks
Good Luck
11/5/2012 5:58:09 AM • Brother... • Answered on Nov 05, 2012
0answers
Why does my printer not print
Ink cartrage could be installed inproperly..the machine Must be close and latched properly also. p.s. Make sure the safty tab is removed from the new cartrage.
6/7/2012 3:30:12 AM • Brother... • Answered on Jun 07, 2012
I am having brother MFC3360c color printer.since last two years color cartridge has not been used, hence so printer head got clogged pl.give solution.
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.Hi,I'm Ben and -- hopefully -- I can provide some meaningful assistance.Even though you haven't used the printer doesn't necessarily mean that one or more of the cartridges haven't filmed over at the tips.The following is a short instructional video on how to clean printer heads. If you still have the same problem, please contact me and we'll try another possible solution.
5/28/2012 10:33:15 PM • Brother... • Answered on May 28, 2012
Brother MFC-3360C All-In-One InkJet Printer Logo
76 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
am having brother mfc3360c color
  • Office Equipment & Supplies
