20 Most Recent
Haier HL26B Television Questions & Answers
Philips 42pfl7662d 12
Entering into service mode to Philips brand TVs is somewhat difficult to an experienced person. There is two modes, SAM & SDM, out of which SAM should be selected. SAM = Service Alignment Mode, SDM = Service default mode. You have to enter SDM first, and should record the data values set there to each perimeter, before entering into SAM. If you wish to get more details about these adjustments, check the site linked here. It has details.
http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar,
or view it in Timslide option. Never attempt to enter to these modes, if you're not sound in electronics, instead, contact the authorized service centre for Philips.
Tv is dead
Common issues are no power reaching set, fuse in set bad, power supply to the set (inside). But if set 12 years old parts may no longer be available.......maybe too old to be a good repair?
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat.
The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions.
I hope this helps. Please add a comment with the model of your unit for further information.
