20 Most Recent Dell D520 Notebook Questions & Answers
How do you change users in youtube?
what do you mean?Is it the your youtube username? It it is, you can change it by signing in in youtube and then edit your profile.
9/17/2012 2:36:57 AM • Dell D520... • Answered on Sep 17, 2012
2answers
Coprocesor drivers amd
i want to audio driverin my laptop modleno-D520 DELL
2/27/2011 12:43:11 PM • Dell D520... • Answered on Feb 27, 2011
Iwant audio drever
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D520&os=WW1&osl=en&catid=&impid=
try on this page, select your operating system and go
2/22/2011 6:06:19 PM • Dell D520... • Answered on Feb 22, 2011
I have a latitude XT,
It sounds like your default profile might have become corrupted. You can make a new profile and transfer your information to the new profile. But before doing that try scanning your computer for virus's amd malware infections.
If you do try the new profile and plan on transferring your information from one profile to another make sure that the old profile is not password locked. Or transfer the information through the Administrator login.
Best of luck...
11/22/2010 3:59:03 PM • Dell D520... • Answered on Nov 22, 2010
2answers
Same as above, with my laptop being studio XPS 1640
Well, as long as your pc is under warranty, Call Dell and have the keyboard replaced. it takes 24 hours to order the part, and 15 minutes to replace it. By this time tomorrow, you could be all set like a new 'vette. Good Luck!
8/31/2009 11:44:16 PM • Dell D520... • Answered on Aug 31, 2009
Dell latitude c six forty numbers on pad do not
THe problem woud most likely be that you do not have the numlock switch on. Are you using a laptop?
8/23/2009 7:58:08 AM • Dell D520... • Answered on Aug 23, 2009
I am facing the exact same problem
Try to once again press Fn+Num lock
8/19/2009 6:08:56 AM • Dell D520... • Answered on Aug 19, 2009
I have an Inspiron 1525 Dell Laptop with windows
You may have a bad connection. You could try taking the keyboard off and unplugging it, then plugging it back in.
If that doesn't work try using a usb keyboard and see if you're able to type. If you can type, try changing the laptop's keyboard, and if you can't type you may have a currupted OS.
If none of these are the problem, you have a bad keyboard port on your motherboard.
7/3/2009 4:57:09 AM • Dell D520... • Answered on Jul 03, 2009
Number keys not working dell laptop
have you or anyone spilt liquid on the keyboard?
do you regularly clean your keyboard?
sorry for the obvious questions but you would be suprised how much chaos it could cause....
here are a few checks for you to do (if you can use a usb keyboard)
1) clean your keyboard of moisture, dirt and grime
2) check your antivirus to do a scan to ensure that the keyboard drivers havent been corrupted by a virus
if still the same then:
3)remove the keyboard and look for corrosion on all pins and/or conectors (corrosion will be a greenish/white color)
if corrosion is found then use a solution (cheapest being vinegar) to clean the pins and/or conectors
if still the same then your keyboards driver maybe corrupt, if so then download the driver from dell's driver site and install, after the instilation do a create restore point or back up your drivers (id put them on a dvd r disk myself) and keep them for future reference.
if this doesn't sort out the problem then it's definately a hardware failure, which means fail......
hope you sort the problem out soon....;-)
4/27/2009 11:13:08 PM • Dell D520... • Answered on Apr 27, 2009
Keyboard not working
Hi Simran Hope you are doing good. Please try the following solution. Press Fn (Function button) on the left bottom side of your keyboard that is between the left Alt and thw windows key and while holding it down press the Num Lk key on the top right side of your keyboard. It is between the Prnt Scrn and Pause button. Please chcek your keyboard and advise if it works fine now or not.
6/14/2007 9:13:30 AM • Dell D520... • Answered on Jun 14, 2007
3answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
4/25/2024 1:51:27 PM • Dell Computers &... • Answered 1 minute ago
2answers
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
4/19/2024 6:52:18 PM • Dell Computers &... • Answered on Apr 19, 2024
2answers
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
My dell laptop i5 does not recognize the external ac source
I would try another power supply and plug that in.
1/5/2024 9:01:17 PM • Dell Computers &... • Answered on Jan 05, 2024
Where is the reset button on the dell inspiron 3052 tag c99f22
Try replacing the BIOS battery for access to the computer.
10/23/2023 4:58:31 AM • Dell Computers &... • Answered on Oct 23, 2023
Are there any other ways to bypass the log on screen on a dell inspiron 3052 so i can factory reset it
Windows can be accessed renaming two files. computingterror.blogspot.com/2014/03/hack-windows-7-login After that being done you should run the Support Assist OS Recovery from DELL dell.com/support/kbdoc/en-us/000177401/restore-your-system-using-dell-supportassist-os-recovery Windows 10 can renew itself, without Windows Setup on a USB medium.
10/23/2023 4:55:37 AM • Dell Computers &... • Answered on Oct 23, 2023
Alpha Lansing ACS400; Dell Inspiron 3020 Windows 11. PC won't recognize speakers. No sound.
Go here [9 Ways] How to Open Windows 11 Device Manager Quickly? - MiniTool Remove all device under sound video and game controllers, and audio in and out.. Then reboot your computer.
10/4/2023 10:39:39 PM • Dell Computers &... • Answered on Oct 04, 2023
Computers & Internet Logo
12 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
coprocesor drivers amd
  • Computers & Internet
