20 Most Recent
Xerox - PRINTERS - PHASER 4510 (N) LASERPR MONO 36PPM 1200DPI 128MB Questions & Answers
How to upload firmware in phaser 4510N
After download the
firmware from Xerox.com website.
Access the device via Http. To do that:
- Open a web browser
- Type the printer ip address into the Address bar
- Navigate to the PRINT tab
- From the left menu select File Download
- Browse to the file you download previously
Before upgrade I advise to print a configuration page for backup.
If you have any doubts just let me know.
Phaser 4510 replace toner message
- This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
- Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered
- Make sure you don´t have any stickers on the toner box.
- If you sure all paper and stickers are out then reset the nvm values from the device in order to reset the printer information.
Hi, my name is Gabriel
There ia a duplex unit that you could buy and attach to the machine.
Alternatively when you select "Print"
Select the option to print pages in the range "odd pages
When the job is finished place the printed documents in the manual paper feed and select "Print" again and the option to print all the even pages.
You will also have to check a box to print pages in reverse order or vice versa depending on the order the first batch were printed.
A bit of trial and error might be required before you get the correct solution. Hope this helps??
