20 Most Recent
Fuji film FinePix Z70 JX520 JV200 Z900EXR T200 Original BC-45A Battery Charger fits Fujifilm NP-45 Without Power Cord Questions & Answers
My camera won't charge
Your battery probably is in the wrong way.So take it out and look on the
bottom of it.You will see 3 copper cubes.Next look in to the slot
where the battery goes and you will see 3 metal wires.Now take your
battery and carefully line up the copper slots with the metal wires.Then
push the battery in and close the battery slot.And your done go plug it
into your USB slot and you will see a white battery symbol and you will
know that it is charging.Simple fix for a simple problem.
6/21/2013 6:17:19 PM •
Fuji film...
Answered
on Jun 21, 2013
Fuji jx520 wont charge
Your battery probably is in the wrong way.So take it out and look on the bottom of it.You will see 3 copper cubes.Next look in to the slot where the battery goes and you will see 3 metal wires.Now take your battery and carefully line up the copper slots with the metal wires.Then push the battery in and close the battery slot.And your done go plug it into your USB slot and you will see a white battery symbol and you will know that it is charging.Simple fix for a simple problem.
6/21/2013 6:13:53 PM •
Fuji film...
Answered
on Jun 21, 2013
How do i control the aperture on my fujifilm finepix jx520?
Like most point&shoot cameras, the JX520 doesn't give you much direct control over the camera. You're just supposed to point and shoot, without worrying about trivial things like aperture and shutter speed.You can get some indirect control over the aperture by selecting an appropriate scene mode. The Portrait and Sport modes, will open up the aperture as much as it can, while the Landscape mode will tend to close it down.
2/11/2013 9:15:38 PM •
Fuji film...
Answered
on Feb 11, 2013
I want to know how to rewind a film reel or Reverse an Elmo FP-A
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Ga645zi lcd repair
That's an old camera so unless you can find a used one to use for parts it's going to be difficult to get it repaird.
