20 Most Recent
SunBriteTV 3200HD-Pro 32 in. LCD Television Questions & Answers
Our sun rite tv screen shows smudges how to clean
Most of these sets the outer part has a coating like on a old camera lens--any harsh or chemical cleaner discolors it--it is permanent damage and just the glass cannot be replaced as it is part of the front screen unit called a display panel.
Hello I recently got a
Either the audio settings are messed up - the easiest way to fix that is to reset them - or the speakers are defective. To check the speakers just connect another set in the outputs at the rear.
By the way the default audio settings are: stereo, all sound processors disabled, and the equalizer set on flat.
Sunbrite tv 32 " 2 yrs old. Blue light comes on ,
Hello Joe Harlinski,Welcome, and thank you for using FixYa!To answer your question: Your television will have to be checked for bad (cold) soldier joints on the power supply board, as well as bad capacitors and resistors.A local Television Repair Professional should be able to handle this for you. If the board cannot be repaired, it can be replaced for roughly $75.00 to $95.00 plus the labor to install it.Have a great day!
The TV 's blue light
Hello alaws,
Your issue will require some diagnostic from your local TV Repair Shop. In today's market, unless you find a repairman that does this work for a hobby, the cost of the parts and labor is higher than the value of the TV.
It may be in your best interest to research the LCD and LED TVs at your local WalMart/KMart/Best Buy.
Have a great day!
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV.
On your Sky Remote, press the TV button.
Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice.
Enter one of the following 3-digit remote codes for Sky TV:
2274
2169
1874
1798
1872
1873
The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code.
Press the Standby button on your remote. If your television turns off, press the Select button to save the setting.
Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful.
Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how:
Repeat steps 1 to 3.
Enter the 4-digit Sky remote code for your TV brand.
Press the Standby button. If your TV turns off, press Select to save your settings.
Check if the TV Guide displays successfully on the screen.
Sky TV Remote Control Codes
