20 Most Recent
Acer Aspire 3100 Notebook Questions & Answers
How to restore to factory settings
VGA chip is probably broken or the solder is loose the only thing you can do if its a loose card try another one or heat the chip with a heatgun on 220 farenheit, not more and only the vga chip there are alot of video's on youtube its not a garanty, but i have fixed 55% of broken ones with this method, if that goos wrong you might break the motherbord because it can be multiple or just one condensator. If you heat a condensator it breaks or explodeds, also remove the battery of the bios they cant stand heat.
Or buy another motherboard.
Windows boot failure. press ok to fix boot failure
Pressing [Alt]-[F10] during the boot-up is what your laptop uses to get to the Acer eRecovery Management UtilityHowever this may not be necessary, although it COULD be a virus, it also could simply be that the boot sector of the hard drive is corrupted/damaged, which can with some OS's be easily fixed, other's, not-so-easy....but still doable. You've GOT to remember to let people know what Operating System you have to better advise you.
MYV LABTOP SLOW HOW CAN
If your internet is slow on the internet explorer. clear the cookies and cache...... click on tools and delete browsing history have everything checked except your passwords it will clean ur computer out...click on the start menu then double like on computer or my computer and right click on the hard drive and then properties and then click on disk clean up and check everything but the password click ok and then run an updated virus cleaner
čo je ERROR pci slot
Hi... problem with our PCI check for bad drivers.... go to your setting control panel system then look for open directory showing a fail driver as to be re-install due to corrupt file inside your system configuration... click update or re-install drivers insert acer cd recovery inside cd-drive and follow instruction
Why won't my acer 3100 accept a dvd-r
Either
* your "optical" device can only read CDs, not DVDs;
* it should read DVDs, but something is "dead", and the device is not performing as it should
* you need to install software to "play" a DVD-movie.
Define "will not accept" -- can you hear the drive spin the disc?
Does any program "auto-start" on your computer, when a DVD disk is inserted?
When i put in a disc the drive light is lit up and
If you open My Computer, and there is no icon for the CD/DVD drive, then your computer has a "hardware" problem. Take it to a qualified technician for trouble-shooting, and possibly for disassembly/replacement of the drive/reassembly.
How can i re boot my computer as bought
You need to reinstall Windows again from scratch using the Recovery CD, if you have not got it you can purchase one from Acer.
Otherwise you nee a Windows installation CD with the product installation code and after you have installed Windows you need to install the device drivers for the devices that are installed on your Acer.
You can d
ownload the drivers from the Acer WEB site Make sure you select the model of your laptop and the XP or Vista version of the drivers you that require matches the Windows version that is installed on your laptop. Use this link to get to the Acer support :-
http://www.acersupport.com/notebook/index.html
My acer 3100 is too slow
Following these simple steps will speed up your notebook...
*Eliminate as many unnecessary programs from startup as possible.
*Run a disk cleanup and disk defrag on your system at least twice a month.
*Uninstall programs that you don’t use
*Unclutter your desktop of shortcuts
*Clear the web browser cache
*Add more memory
