20 Most Recent Mercury Electronics CyberPix S-555V Digital Camera Questions & Answers
0answers
2answers
I have a Mercury cyberpix s 541s digital camera
what warranty you can't even find these people cause im searching too
9/7/2013 6:46:53 PM • Mercury... • Answered on Sep 07, 2013
0answers
I have a cyberpix s-830d and aftera couple of pics
Hi kane_ell,
Depends on the battery's usage , if you have been using the batteries for quite , long then most probably it's the time for replacement.
However if the batteries are new then the problem is with the firmware which needs to repaired by the service center , so you can check if the camera is under warranty and do it for free , else inquire about the repair charge and check if that is OK with you.
Hope that helps ..:)
9/9/2011 1:03:50 PM • Mercury... • Answered on Sep 09, 2011
I accidently took the memory
First take the memory card out of the camera. Pictures that have been deleted, if that is what has happened, are probably still there, but will be overwritten if you take any more pictures on top of them.
Your camera is not able to undelete pictures, but there are programs for doing this on a computer. You can put the memory card into a card reader attached to a computer, and use an undelete program to recover the deleted files. Undelete programs are available for free download from the internet, try the one at THIS LINK This program can even get back pictures from a card that has been formatted.
If the pictures are very important to you, you might want to seek help from an experienced person.
11/25/2010 7:07:18 PM • Mercury... • Answered on Nov 25, 2010
Las baterias no duran
Trate de buscar en línea para una batería de repuesto para su unidad ...
2/24/2010 7:20:30 PM • Mercury... • Answered on Feb 24, 2010
I can not get my
First, you need to verify the supported operating system of your camera. Check the user manual and the supported OS should be listed there.
If the camera could support up to Windows Vista only, then we cannot expect that it will work with Windows 7.
However, you may contact the manufacturer of the camera and ask them if they have an updated driver that you need to install in your computer to make the camera work.
Good luck and have a good evening!
1/19/2010 6:03:52 AM • Mercury... • Answered on Jan 19, 2010
Problem connecting cam as a webcam
pls downlaod the manual it will explain u in detail
http://www.mercurystyle.com/manuals/S555ManualEnglish.pdf
3/17/2009 12:28:52 PM • Mercury... • Answered on Mar 17, 2009
Lost instructions
pls download ur instruction manual from the link below and Please rate me FIXYA if i helped u
3/17/2009 12:26:48 PM • Mercury... • Answered on Mar 17, 2009
With 5-megapixel camera, I want to capture maximum resolution.
how I get maximum resolution by 5 mp camera with small photo.
my friend mega pixel relates to the print out u want out of ur photo file,on the monitor screen everything looks same if u dont zoom too much ,
for 5X7 print 1 mega pixel photo looks fine and more than enuff if u want a 5X7 print out of it
for 6X8 and 8X10 2 mega pixel is ok and for further enlargements u need higher mega pixel
or if u need output on large LCD screens of like 46 inch and 52 and 60 inch then also u need good resolution pics to display properly other wise pixelation will appear
so how can i help u more in this pls rate me FIXYA for this if u like
3/17/2009 12:16:32 PM • Mercury... • Answered on Mar 17, 2009
My camera is not starting
Read thre Manual- It is likely you have an oversize card.
The manual will tell you the max size card the camera will handle
1/1/2009 7:31:20 PM • Mercury... • Answered on Jan 01, 2009
Software
You can get the software here.
http://www.driversdown.com/drivers/Mercury-S555V-CyberPix-Digital-Camera-Driver_77804.shtml
Good luck and Please rate FixYa!
12/25/2008 8:32:53 PM • Mercury... • Answered on Dec 25, 2008
Everytime I take a picture it turns out blurry
Inside the lens their is a focus motor that has to be perfectly set if it get out of ajustment this will cause a blurry image it you try to zoom some times you may get a lens error this is because the lens has been obstructed from the inside by the focus lens. the lens eather needs to be replaced or rebuilt.you may find a broke one off ebay with a good lens pretty cheap if you are going to try and repair it your self.
12/6/2008 6:28:57 PM • Mercury... • Answered on Dec 06, 2008
0answers
Cam prob
Have you tried absolutely fresh batteries of the correct type? If so Then it would seem that the lens mechanism is not fully functional. DO NOT TRY TO FORCE THIS - IT IS VERY FINE AND CAN BE WRECKED BY THE LIGHTEST TOUCH OF FORCE. Turn off the camera remove the battery and with the eraser on the end of a pencil polish the internal contacts in the base of the battery chamber. Do the same for the chamber lid. Hold the camera lens down and gently tap the side of the lens mount. Re assemble -see what happens. If still in trouble go to customer support on the makers website.
8/11/2008 6:32:40 PM • Mercury... • Answered on Aug 11, 2008
Mercury Electronics CyberPix S-555V Digital Camera Logo
Popular Tags
33 questions posted
Top Mercury Electronics Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Mercury Electronics Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Mercury Electronics Cameras
Most Popular Question
lost instructions
  • Cameras
