20 Most Recent
LG M4201C-BA 42 in. HD-Ready LCD Questions & Answers
My 42lh30 lg tv was on the kids where watching
Possibly you've had a power cut & a fuse associated with the TV has blown. Have you checked the fuse in the TV plug? If that's ok then probably a fuse internally in the TV has blown or something more serious has blown in the power supply
Attempting to find a mount
Tries websites Amazon.com,Ebay.com to buy a wall mount kit for 42 to 50 tv mount will fits and work it is design to fit up to 50" LCD and Plasma tvs.
Remote not working
Check the remote control for its infrared emission. Check it with fresh batteries. Check and clean the battery contacts inside the battery comparment, for any rust or dust accululated, prevents proper battery connection. Clean it well, berofe inserting batteries. If you are using a universal remote control, you have to set it up with the set-up code to your TV brand, otherwise it won't work properly. If you wish to get more details,
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
