20 Most Recent
Audiovox FPE2706 27 in. LCD Television Questions & Answers
The picture comes on fine, but suddenly, no audio
<span style="mso-bidi-font-family: Arial">Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, and then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.</span><br />
<span style="mso-bidi-font-family: Arial">Parts: <a href="http://www.shopjimmy.com/">www.shopjimmy.com</a></span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br />
<span style="mso-bidi-font-family: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Screen is black and no sound after toddler played with remote
What have you tryed so far, unpluging Tv and wait 10mins and try again?Have you removed back and Looked on power supply board for bad capacitors they will be swollen,vented,or puffed up on Top ,if you see any that look like that they are bad. 1000uf 16v 220uf,330uf 10v
Fpe2706
my LCD 1081 TV won't turn on only red light flashes all the time, and it is a brand new one only 3 days ago i bought it
Blue light on antenna isn't turning on remote start won't work.
It's possible that the issue with your Audiovox pursuit PRO9056c remote start system is related to the antenna or its connection. Here are a few things you can try to troubleshoot the issue:
- Check the antenna connection: Make sure the antenna is properly connected to the control module of the remote start system. You may need to remove the panel where the antenna is mounted to access the wiring and connections. Check the wiring for any signs of damage or corrosion, and make sure the connections are tight.
- Check the fuse: The remote start system may have a fuse that is responsible for powering the antenna. Check the fuse to make sure it is not blown or damaged.
- Reset the system: Try resetting the remote start system by disconnecting the battery for a few minutes, then reconnecting it. This may help reset the system and resolve any issues that were causing it to malfunction.
- Consult a professional: If you are not familiar with automotive electronics or are unable to resolve the issue with the above steps, it may be best to consult with a professional technician who can diagnose and repair the system for you.
It's also possible that there is a problem with the remote start system itself, such as a malfunctioning control module
2/16/2023 10:58:50 PM •
Audiovox...
Answered
on Feb 16, 2023
I have a Audiovox d1988 and the screen won't play. I have sound but no picture. Help!!!
Jim,
First thing I would do is try a different DVD to see if the problem persists. Otherwise, this device is equipped with integrated speakers, meaning it is unlikely that you will be able to replace them. You may be in the market for a new Audiovox, unfortunately; but before you scrap it I suggest taking it to a local electronic repair store near you.
Hope this helps,
Best regards
3/8/2019 11:36:14 PM •
Audiovox...
Answered
on Mar 08, 2019
