20 Most Recent
Vivitar ViviCam 5386 Digital Camera Questions & Answers
Sd card error memory
Your card has likely failed. If you have information on it you should use recovery software to recover the data and then throw away the card. :(
Diane
NYC Photo Safari
How do I fix the black screen
Can you get to a menu? if you can get to your menu then turn the screen brightness up. IF you can't even see the menu then the screen has failed and will need to be replaced or repaired.
Diane
NYC Photo Safari
How to recover deleted pictures
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead. If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.If the deleted files are on a memory card or USB memory stick, just don't save any new files to it. One of the easiest ways to see if you can
recover deleted pictures is to try some photo recovery software. Recommended this photo recovery as it saved my life many times.
http://www.asoftech.com/apr/
CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
Driver download
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Manual for vivitar vivicam 5386
Hi Don:
We have find two choice to doanload this document with information about Vivitar ViviCam 5386 Digital Camera:
filedetail.php/vivitar-vivicam-5386-manual-eng-zipThe second choice is contact us in this link or clicking over image to send download instructions: Digital
Cameras User Manual
I hope this helps; keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Thank you for using Fixya, and have a nice day.
I am trying to get
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
What is the dial on
According with the conditions to take a pic, could be select the next choice...
I suggest download and check this User Manual for this and other details:
Vivitar ViviCam 5386Good luck (remember to rate and comment this answer).
When powering on the camera comes on lense extends
Your camera almost certainly has a lens error, this
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Vivitar service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault. Although the article
mentions Canon a few times, the advice applies equally to all cameras
with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera, or
at least are able to use the information to help decide whether to buy
another camera. If you do
decide that you have to throw your camera away then don't forget to
remove the memory card as it can be used in other devices.
Please take a moment to rate the free answer I have provided
for you and
any testimonial which you might wish to add is always welcome.
Lost my connection cord to go from the camara to
Consider NOT using the USB cord.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
My Camera lens trys to
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes
of a Lens Error: There are a number of ways with which a lens error can
be caused. Particulates might have managed to get into the mechanical
bits that allow the lens to retract, a purely physical interference with
the lens mechanism. If the camera was dropped, especially while the
lens was extended, there's a pretty good chance something might have
been knocked loose, such as the guide pins upon which the lens withdraws
and retracts.
How to Repair a Lens Error: As scary as a lens
error might seem, there are some easy fixes. Before trying any of them
out, however, first take a good long look at your camera warranty and
maybe have a chat with the company. If the lens error will be covered
under the terms of the warranty, go for it. Even some of the simple
fixes mentioned below might void the camera warranty. Frankly, however,
it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
