20 Most Recent Dewalt Dcf885 20v Max Lithium-ion Cordless 1/4" Impact Driver 20 Volt Questions & Answers
Battery will not charge charger lights up to begin
The cells in the battery have gone bad
1/17/2014 12:18:35 AM • Dewalt Dcf885... • Answered on Jan 17, 2014
DeWalt planer leaving little gouge marks on the board. Recently had a new chain installed. Any help would be greatly appreciated.
It needs new blades - likely has a chip in one. See link for replacement tutorial
6/14/2022 4:37:07 PM • Dewalt Tools &... • Answered on Jun 14, 2022
Dewalt dc618 nail gun won't shoot
https://www.weeklytools.com/dewalt-angle-grinder-buying-guide/ When it comes to Angle Grinder, the name of the Dewalt tools maker comes first. We will look at the basic parts and functions of a grinder before purchasing a machine. Then let's see the details without delay.
3/13/2021 8:23:58 PM • Dewalt Tools &... • Answered on Mar 13, 2021
How do you change blades on DeWalt DW50 planer
https://www.weeklytools.com/different-uses-for-an-angle-grinder/ An angle grinder is a multifaced handheld power tools that was invented by a German company. We may don't know a lot about this tool because it is an unrecognized instrument like some other tools. Now we will discuss different Uses for angle grinder. An angle grinder is also known as a side grinder or disc grinder. It is a machine with a rotating abrasive cutting disc. Angle grinders can be powered by an electric motor, petrol engine, or compressed air. It comes in a wide variety of different sizes and powerful motor, each with the other purpose. Once anyone knows about these, he can easily find out the best angle grinder for his needs. Angle grinders are quality fulled equipment for any metal fabrication shop, and those are typically used in auto repair, workshops, and construction sites.
3/13/2021 8:22:33 PM • Dewalt Tools &... • Answered on Mar 13, 2021
Model DC618 nail gun. Why does it start, then shuts down as soon as I depress to fire nail?
https://www.weeklytools.com/how-to-use-a-nail-gun-with-an-air-compressor/ We may not need a drill machine almost the whole time. But there is a demand for a pilot hole during the home finishing process. This post is not for you if you are a professional. However, in most of the cases, we observe the necessity for a pilot hole. From wooden doors and windows ...
3/11/2021 9:28:06 PM • Dewalt Tools &... • Answered on Mar 11, 2021
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
2/3/2021 5:13:02 PM • Dewalt Tools &... • Answered on Feb 03, 2021
My dewalt 1223 brad nailer will not fire
The nailer must be firmly pressed against the surface you are planning to nail. This will arm the nailer in preparation for firing the nail.
10/3/2019 9:15:00 PM • Dewalt Tools &... • Answered on Oct 03, 2019
Speed control wire around on DW423 sander
Try this link: https://www.ereplacementparts.com/dewalt-dw423-type-inch-evs-random-orbit-sander-parts-c-1009_2742_2758.html
4/2/2019 10:42:12 PM • Dewalt Tools &... • Answered on Apr 02, 2019
Changed blades on 733 dewalt planer now rollers not working could it be associated chews up broards
Either the blades are incorrectly installed causing the head to jam or the safety cover is not installed properly - there is a safety mechanism that locks the cutter head when the cover is removed.
2/2/2019 6:38:10 PM • Dewalt Tools &... • Answered on Feb 02, 2019
Hi my new dewalt first fix nailer(2018) will fire a few nails but then the battery light starts flashing? does this with all 4 of my batteries fully charged
Typical cause is low voltage - but can also be a bent driver or something jammed in the nail track. Is this a finish nailer or framing nailer?
2/2/2019 6:35:23 PM • Dewalt Tools &... • Answered on Feb 02, 2019
I have a dewalt 18g DC608 finishing nailer I bought, and I’m using it with a 18v adaptor with 20v batteries. It lights up and fires maybe three nails but when the motor gets going it always cuts power and I have to remove the battery and put it back. Anybody else had this problem?
That symptom usually indicates a low voltage issue - not sure how the adapter may affect this, I've never run them with a 20v battery. Try it with a standard 18v and see if you have the same issue - please comment back with the results, I'm curious.
2/2/2019 6:18:34 PM • Dewalt Tools &... • Answered on Feb 02, 2019
Dewalt Mk246 won't run. , It's Brand Nu was
This is a common problem with this compressor and still is a problem in 2014.It is under powered and trips the reset
2/1/2019 11:24:39 PM • Dewalt Tools &... • Answered on Feb 01, 2019
Replace belt Dewalt d55168
copy and paste in search engine. took about 5 seconds to find answer. Dewalt Air Compressor D55146 Belt Replacement
11/23/2018 1:12:35 AM • Dewalt Tools &... • Answered on Nov 23, 2018
2answers
Why won't my DeWalt DC618K air nailer fire?
Without inspecting tool, it would be hard to definitely tell what part, I would call Dewalt, they will be glad to help you. You do not want to throw parts at it. 1-800-433-9258
11/20/2018 4:16:28 PM • Dewalt Tools &... • Answered on Nov 20, 2018
Dewalt Dcf885 20v Max Lithium-ion Cordless 1/4" Impact Driver 20 Volt Logo
1 questions posted
Top Dewalt Tools & Hardware - Others Experts
john h
Sean Wright
Sean Wright
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Tools & Hardware - Others
Most Popular Question
battery will not charge charger lights
  • Tools & Hardware - Others
