20 Most Recent
ViewSonic N3252w 32 in. LCD Television Questions & Answers
I have brightstar remote BR100
I really could use the code for brightstar uni. Remote B100 for the Senior TV. I think it is manufactured by Sentrics it is a hospital TV.
I am wondering if there is an in-line fuse that
Viewsonic 32" TV has an inline fuse. It is soldered to the power board. It is a small black cylinder. You can order a replacement fuse from aliexpress. Cost is about $1.40, but I had to purchase 10 for total cost of $14
Why is white bright screen
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
No hdmi
check the source which gives you the signal for the hdmi! for an example, if you hook up you lap-top via hdmi with the tv, there is a setting on the lap-top and you choose: 1. transmit picture, 2. transmit sound, or do not transmit anything.
Power lock is on
There are keyboard locks that will lock the remote out on all functions there and remote lock outs that will do the same for the remote but both usually will not lock just one feature out especially if the power button works on the set but not with the remote.
How to reboot N3252W
Unplug the power, wait an hour, then plug it back while holding the power button down. This will reset back to factory settings and most likely will solve your problem.
