20 Most Recent
Samsung LN-S3238D 32 in. LCD HDTV Questions & Answers
I have a samsung LN-S3238D
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
7/6/2017 11:10:12 AM •
Samsung...
Answered
on Jul 06, 2017
I have a ln-s3238d that i got a couple years ago.
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
11/5/2010 9:30:39 PM •
Samsung...
Answered
on Nov 05, 2010
My Samsung LN S3238D won't
hello, Normally the power supply board has to be replaced. It is cheap if you do it yourself since you only pay for the board. These sites normally sell them, shopjimmy.com or discount-merchant.com
hope this helps
8/26/2010 10:03:22 PM •
Samsung...
Answered
on Aug 26, 2010
Samsung LN S3238DX display issues
Hi, Your LCD controler is bad. Part number...
320WTC4LV1.0 Also does it do it on the tv menu?
If not it is the Main Pcp board "logic board" part number ...BN94-01011C
10/27/2009 11:09:57 AM •
Samsung...
Answered
on Oct 27, 2009
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I troubleshoot my Samsung TV?
I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
