20 Most Recent
Canon PIXMA MP960 All-In-One InkJet Printer Questions & Answers
Nozzle head blocked been through all the
The nozzles are block, this is cause be periods on non use. The print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
I HAVE A CANON PIXMA780 IT HAS NO POWER GOING TO
Have you checked if there is any loose contact in cables ? Check the cables connectivity.
Remove the plug from the surge protector or wall jack and try connecting it to another location.
If none of this works, it could be a detective power adapter ( the black box ) on the power cable. See if you have spare one or can find one to diagnose and know if it is the power adapter issue or the printer is dead.
IF your printer is In Warranty, you should contact Canon Support as they can provide you replacement without charges.
Regards,
Ron
My MP960 will not take the paper in from any end.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Drivers and Manuals for PIXMA MP960 Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon
Pixma MP960 photo all in one printer.
Drivers for this printer are available for Windows
98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions,
windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X
10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and
other instructions are also available.
To download these drivers and or documentation for
your printer please visit THIS
PAGE
Note that the picture below
reads mp730 but the actual page linked will be for MP960
1.
Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac
etc )
3. All available drivers, documents etc will be
available below.
For some of the documents a PDF reader may be
required to open and read / print them.
To obtain a PDF reader, read this page PDF
Documents. Pdf reader(s)
Thank you for reading and I hope your printer is
up and running again.
-Ekse
The ink is fine. The error code comes up and the
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Mp960 won't power up
How long have you owned the printer how long have you had this problem? The printer does nothing at all? Are you trying to service repair the unit yourself or have it serviced by a professional? Once i have more information I can assist you further.
thank you,
Lee
It is in Japanese and I want it in English
Dear Sir,
Welcome to Fixya.
Here is the Solution.
It is not problem with catridge.Go to Language setting change language option from japanese to U.S.English.It solves your problem.
Good luck
