20 Most Recent Samsung L73 Digital Camera Questions & Answers
Each photo shows on the sceen either totally white or very bright with lines across
If this is showing on the photos you have taken, it may be a white balance issue, or exposure compensation set too high. If it is only on the monitor, a possible cause is that you have the LCD illumination set too high. Look for these suggestions in the problem-solving section of the manual.
1/27/2016 11:37:11 AM • Samsung L73... • Answered on Jan 27, 2016
Www samsungcamera com
It seems to me that the camera is overexposing the images. First make sure that the 'ISO' is set to a lower value such as 100 or 200. Also ensure that the Exposure Compensation (+/-) is set to '0'. For this, you might need to put the camera on 'P' mode.
8/25/2014 6:23:50 AM • Samsung L73... • Answered on Aug 25, 2014
0answers
2answers
How to upgrade the firmware on samsung L73?
Go to the samsung camera web site and find the firware for your camera and use the usb cable and it will let you download the info.
9/26/2011 4:09:23 PM • Samsung L73... • Answered on Sep 26, 2011
Can't find my charger, where
You can purchase one from Amazon.com, they are currently less than $10.
http://www.amazon.com/Original-Samsung-Digital-Camera-Charger/dp/B004C1RESO
5/5/2011 4:59:25 PM • Samsung L73... • Answered on May 05, 2011
LAS IMAGENES SALEN NEGRAS
You have screen problem on back lights. Please get it replace at dealer
Regards
2/9/2011 6:23:46 PM • Samsung L73... • Answered on Feb 09, 2011
My samsung L730 digital camera will not turn on, i
Some lithium-ion really loose their life easily and sometimes quickly.They are affected by temperatures too.I noticed that when I am charging the batteries tend to heat up and I found out they loose their power quickly when you let them charge and leave them warm.Secret to of prolonging their life is after a full charge zip lock it and freeze them.Of course dry them upon use.Do try a new set of batteries it will resurrect your camera back to life.
11/25/2010 8:44:03 AM • Samsung L73... • Answered on Nov 25, 2010
My Samsung L73 digital camera will not charge.
Have you recharged the battery many times since you owned it? Did you leave it alone for an extended time and it completely discharged and died? Rechargeable batteries sometimes only last 3 years.
6/14/2010 3:56:58 AM • Samsung L73... • Answered on Jun 14, 2010
Stripe appeared when taking picutre with SAMSUNG L730
The shutter is jammed open - in picture mode it overexposes and gives the white stripes, in video the shutter stays open and the camera sets the expsoyre, so appears OK. New lens unit will be required.
6/10/2010 2:59:45 AM • Samsung L73... • Answered on Jun 10, 2010
Samsung L73 when taking picture says low light
Have you tried setting the ISO to a higher setting?
4/2/2010 7:19:23 PM • Samsung L73... • Answered on Apr 02, 2010
Can you us this camera as a webcam?
No it cannot be used as a webcam.
regards
2/20/2010 9:08:48 AM • Samsung L73... • Answered on Feb 20, 2010
Lense is stuck open
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
1/15/2010 3:10:51 PM • Samsung L73... • Answered on Jan 15, 2010
My camera got sand in it and it wont take pictures
We can not fix anything, but if it is under warrantty, try sending it to samsung, they can fix it for free if it is not "accidental damage" or, can fix it if it is for about 100- 150 $.
7/15/2009 1:48:52 PM • Samsung L73... • Answered on Jul 15, 2009
Overexposed with lines in photos
this is not ur fault ! Thousands are suffering bcoz of this manufac fault
it is a possible CCD FAILURE !
dont worry it is a manufac fault in CCD's Samsung will also do it Free of charge pls see the link and call them and PLS RATE ME FIXYA for help
http://www.imaging-resource.com/badccds.html
dont worry if u are not on list just call them !
pls dont forget to rate me
5/7/2009 6:06:45 PM • Samsung L73... • Answered on May 07, 2009
Can't transfer pictures to pc.
you can download the drivers of your cammera on the internet and install them...
try in google or in the website of the cammera´s brand.. there you could find the drivers..
if you still have problems i could help you finding them..
cheers
3/24/2008 4:34:19 AM • Samsung L73... • Answered on Mar 24, 2008
2answers
Samsung manual for 2.1 soundbar subwoofer m AH68-02078F
How i connect to my tv
4/16/2024 1:24:29 AM • Samsung Cameras • Answered on Apr 16, 2024
Samsung ES80 Digital Camera. It is not charging and the red light is not flashing.
The battery has probably failed due to lack of use and regular charging Remove the battery and check it with a multimeter. To see the camera on your laptop you would normally need the software and drivers for it. Support link https://www.google.com/search?q=samsung+es80+software+download Battery https://www.google.com/search?q=samsung+es80+battery ..
2/18/2024 8:00:02 PM • Samsung Cameras • Answered on Feb 18, 2024
Samsung L73 Digital Camera Logo
21 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
stripe appeared when taking picutre
  • Cameras
