20 Most Recent Acer AL1716 17" LCD Monitor Questions & Answers
2answers
I had a acer lcd monitor al1716 that has a vertical lines in a block running across the screen with horizontal lines inside
If you have tried a different monitor and still get the vertical lines the problem lies either with your cable or graphics card or motherboard (if you don't have a graphics card). If you are running a graphics card take it out and put it back in and check if it still shows you the lines, if so remove it and try using the on board graphics from the motherboard. 'f the problem disappears its the graphics card if not its the motherboard.
5/26/2015 7:31:08 AM • Acer AL1716 17"... • Answered on May 26, 2015
2answers
Will an Acer AL1716 monitor work with a Dell 4600?
http://reviews.cnet.com/desktops/dell-dimension-4600-for/1707-3118_7-30529709.html
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
12/1/2014 5:05:06 AM • Acer AL1716 17"... • Answered on Dec 01, 2014
3answers
What is the screen resolution for acer al1716
Hold the power button down for at least 10 seconds till the light goes out, then turn it on and the problem is gone.
12/1/2014 5:04:18 AM • Acer AL1716 17"... • Answered on Dec 01, 2014
3answers
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
12/1/2014 5:00:30 AM • Acer AL1716 17"... • Answered on Dec 01, 2014
2answers
No power after monitor is plugged and turned on
seen this problem many times, do as above stated. Return the moniter to where you bought it, if just purchased. Contact Acer if it is still under warranty.
12/1/2014 4:59:39 AM • Acer AL1716 17"... • Answered on Dec 01, 2014
2answers
MONITOR ACER AL1716
1. Unplug the AC power cord to make sure the power is off.
turn the monitor upside down, you need 2 people for this.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base.
12/1/2014 4:55:18 AM • Acer AL1716 17"... • Answered on Dec 01, 2014
Monitor is slow coming on
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor. 2. Verify the monitor cable is firmly connected to the computer and the monitor. 3. Verify that you have turned the monitor power switch on. 4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works). 5. If the power light on the monitor is not on, try a different power cord. 6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
5/28/2014 4:18:49 PM • Acer AL1716 17"... • Answered on May 28, 2014
Monitor flashes on websites
if problem persist when opening multiple tabs, your RAM (random access memory) might be failing or is cluttered by a virus or program. If there is not enough memory available, the screen will go crazy or have a hard time coming on. Next you can check your video card if its not an integrated one. You may need to use a cheap used card to make sure that it is not a video card problem.
4/3/2014 2:44:10 AM • Acer AL1716 17"... • Answered on Apr 03, 2014
Slow monitor
Check the video/display settings in your OS. System Preferences in mac os Screen resolution in windows. Use recommended settings.
3/27/2014 1:50:17 AM • Acer AL1716 17"... • Answered on Mar 27, 2014
0answers
I have a problem: I have connected second (old) monitor Acer AL1716 to laptop with Windows 7 (x64). But it has no drivers for such an old gadget. The resolution is set 800x600 as default and is unable
monitors need drivers only to do color calibration, otherwise the resolution is automatically recognized. try to update your graphic card drivers
3/13/2012 1:29:17 PM • Acer AL1716 17"... • Answered on Mar 13, 2012
0answers
I have an acer al1716
the video settings on your computer has changed to a setting that the monitor doesn't like! try entering your computer in safe mod and change the setting to a max of 1024x768. however, if your video card has a dual output and you have 2 monitors connected at the same time then this is your problem. make sure that the 17" lcd is monitor 1 and the other monitor #2. one of the monitors is set higher the the 17" lcd and when it is not connected the computer may think this the setting for the 17" lcd and not the other monitor which may be hdmi or 1900x1080 which the 17" cannot read this it is out of range!
8/24/2011 1:28:50 PM • Acer AL1716 17"... • Answered on Aug 24, 2011
2answers
You should have no problem connecting the monitor to the VGA port of the Dell that is already comes with the computer, just make sure to set the video output resolution to be at native resolution of the monitor, which is 1280 x 1024 @60Hz.
6/20/2011 5:36:36 PM • Acer AL1716 17"... • Answered on Jun 20, 2011
2answers
My display unit of my ACER PC show no signal,but
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
6/2/2011 9:19:37 AM • Acer AL1716 17"... • Answered on Jun 02, 2011
Acer AL1716 17" LCD Monitor Logo
112 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
monitor takes forever come warm up
  • Computers & Internet
