20 Most Recent
Sony VAIO VGN-N230E/B Notebook Questions & Answers
Sony Vaio W series not
Click start,double click Conrol Panel,double click Device Manager.
Once the Device Manager open's,expand batteries(Click on the +). RIGHT click AC Adapter and select update my driver online. After you finish updating the AC Adapter,update the Compliant Control and that SHOULD take care of your problem.
2/12/2011 11:01:16 AM •
Sony VAIO...
Answered
on Feb 12, 2011
My sony vaio vgn n230e/b laptop won't recognize a
If you replaced the battery from one of the many sites that promise complete compatibility with the original OEM battery with specs that meet or exceed those of the OEM, you're on the wrong track. They don't work in my experience. Sony has a proprietary chip in their battery packs that identifies it as an "original" The battery sites state that you have to update the BIOS drivers to make it work and if you have Windows 7, it will be problematic. I've gone through this several times, and what I've had to do is do a restore to a point prior to installing the software that the battery site provided. Although I received a notice that the restore was unsuccessful after it had been run by a system restore CD that you should make; I received notice that the restore was successful after reboot. I then ordered the battery from Sony, installed it, and all is well. Best advice is to be very circumspect in getting batteries from any source that says they are brand new and are completely compatible. A place I know to go to replace bad cells is www.batteryrebuild.com or batteryrefill.com (same site). They replace the cells, leave the original chip, and the computer sees it as an 'original' Sony battery.
12/30/2010 8:35:36 PM •
Sony VAIO...
Answered
on Dec 30, 2010
How do you replace a keyboard on a sony vgn n230e
you can ask the sony vaio people if the keyboard is replaceable.. if they sell it from parts, most likely you can replace it yourself, if not, then last option is to send it for cosmetic repair which may cost you $169.99 plus shipping and tax..tech support number is 888 476 6972
4/9/2010 9:52:18 PM •
Sony VAIO...
Answered
on Apr 09, 2010
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
