20 Most Recent
Canon EOS-1D Mark III Body Only Digital Camera Questions & Answers
Why are no photos being displayed on screen after shooting?
https://www.learn.usa.
canon.com/.../CDLC_
EOSLiveView_Q...
Canon Inc.Canon EOS cameras when used in their Live View mode. ... directly onto the sensor, which in turn displays the image ... EOS 40D, 5D Mark II, EOS-1D Mark III, EOS-1Ds Mark III, ... Mark III do not offer movie options. ... to produce a fixed screenbrightness, or Exposure .... settings for the following camera menu options:.
https://support.usa.
canon.com/kb/index?page=content&
id=ART134415
Nov 4, 2015 - ID : 8201360200 _ EN _ 1. Solution ... While the Live View image isdisplayed, you can press the < AF?????????DRIVE > button to select the AF mode on the setting screen displayed. 9. ... If focus is not achieved, the AF point will turn orange. .... Shooting movies with the default settings (EOS 5D Mark III)
At my canon eos 1
Usually this error comes up when the golden contacts between the camera body and the lens are dirty or defective. You can try cleaning it with appropriate contacts solution and a microfiber cloth or simply by scrubbing them with an eraser (be careful though not to let fall any gunk or gum dust into the camera). Never touch those contacts directly with your fingers.
Another culprit may be a defective CF card, try a different one and see if something changes.
If this doesn't solve the issue and your camera is still under warranty, i suggest you to have is serviced from canon. When out of warranty solving this issue is going to cost you several hundred dollars.
Let me know if this helped, best luck
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.usa.canon.com/cusa/professional/products/professional_cameras/digital_slr_cameras/eos_1d_mark_iii#BrochuresAndManuals">THIS </a>link
you can download your cameras user manual on your computer and thus
keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
Focusing
If not everone is in focus, try switching to M or Av mode, and turningthe f number up, which will allow for a greater range of focus.
7d - problem with shots remaining
Maximum for counter is 999. Counter is showing 999 because you have space available for more than 999 shots. If you've got a very large memory card it may tke quite some time to get below 999.
1/13/2018 7:54:04 PM •
Canon Eos...
Answered
on Jan 13, 2018
Top edge of my photo is a black diagonal shadow
Sounds like it could be vignetting from either a lens hood or an accessory. Are you seeing this in all photos or flash only? If flash, sometimes a wide shot with a lens hood on will block the flash output and cause the described shadow line.
11/17/2017 10:46:15 PM •
Canon Eos...
Answered
on Nov 17, 2017
Why is there nothing showing in my lcd after I turn camera on?
This is an indication that the LCD is not functioning. You haven't indicated the make and model of your camera but if it has a view finder, try taking some picture and view them in a computer. No view-finder? Just point and shoot some subjects and view then from a computer.
Are the pictures OK? If they are than you might want to maintain that style while looking for replacement parts of service tech.
10/28/2015 1:31:45 AM •
Canon Eos...
Answered
on Oct 28, 2015
I am unable to take photos using my EFS 18-55 lens
When you have another lens, that still works on the same camera, you can assume it is something with the 18-55. Please check carefully if all contacts are clean and shiny. Also check if not one has a (even tiny) bent to dent.
You can clean contacts with a dry cloth, or cotton swab. Never use anything sharp in or lost by a camera.
If you can't fine anything obvious wrong with the contacts, I think you should visit a Canon certified service centre.
Came just in my mind. If the camera does not give any error, and you still can shoot (blurred) pictures, check if the AF switch is not on manual.
11/20/2014 7:06:55 PM •
Canon Eos...
Answered
on Nov 20, 2014
How do I install the ds 126071 0n my laptop?
Although the manual does not show how to connect to a computer, the system map shows how to use a mini USB cable to connect the camera to a PC. But before the camera will communicate with any PC or Laptop, it needs software.
From the Canon USA website you still can download the Zoombrowser EX software for free. It used to be the EOS Digital solution disk and the ArcSoft PhotoStudio Disk.
Before connecting the camera, install the software. Then when software (and driver) are installed, when connecting the camera, the software will start up and ask what to do. Like import the pictures to the computer.
Success
11/20/2014 4:26:51 PM •
Canon Eos...
Answered
on Nov 20, 2014
