20 Most Recent
Sony DCR-VX2100E Camcorder Questions & Answers
Bars across after reply recording
hi,
your camera's head is either damaged or may be dirt on the scanning chip of the head, try to clean it with a head cleaner tape, if the head is effected with clog, try to clean it several times. then test it with a prerecorded cassette. if there is no any progress, it means the head is faulty, it must replace with a new one.
How do I clean a Dyson DC 23 so it will pass quarantine inspection when moving overseas (to New Zealand)
you will to ontact the customs office in Kiwiland for that answer. In most cases cleaning the hopper in warm soapy water and buying new filters is enough. Some places require a hospital grade detergent such as wESCODYNE be used to include the air hose(s). Please beware, the AC power in AU/NZ is 230 VAC, so you will need a step down power transformer to use it there. (You'd be better off just buying a new one there to be honest, then you needed worry about lugging a heavy power transformer around of changing the plug end to the Clipsal type used in AU/NZ.)
