20 Most Recent Pentax K10D Digital Camera with 18-55mm Lens Questions & Answers
Pentax K10D shutter release won't function, mirror doesn't open, all else normal.
Pentax K10D... | Answered on Jan 17, 2010
Make sure the software that came with the camera is NOT installed. Assuming it is with a Windows computer with ME/2000/XP. Plug the camera in, ensure it is on and set to upload and Windows will take it from there. Windows Scanner/Camera wizard will come up and ask what you want to do with the images- simply select to download to folder- from there it can be allowed to simply follow its head and make its own folder usually taking the date as a title - -or make a dedicated folder or subjects names the whole operation is controllable by the user providing that take their time. It is essential the Software disk is left in the box - it only confuses things - computer and user.
Pentax K10D... | Answered on Apr 11, 2009
Did you put a memory card in the camera?
My camera did this today, and I resolved it by putting a memory card in, but even when one has been out before it still turned on, so I'm not sure that is the resolution. Did you ever find out what was causing it?
Pentax K10D... | Answered on Jul 28, 2008
The picture displays after the file has finished saving - if the speed of your SD card is slow, it can take quite a while before the picture is displayed. It also takes a while (up to a minute or more) if the shutter speed is low and the picture is mostly black (taking nighttime moon shots for instance).
Try using a better quality (higher speed) SD card.
Pentax K Cameras | Answered on Dec 01, 2015
Your old Pentax lenses uses the Pentax K mount. The current Pentax digital SLRs all use the same K mount so the lenses will fit on them. You obviously won't get all the features available on new lenses, such as autofocus, but they should all work fine.
Pentax K Cameras | Answered on Dec 31, 2012
http://www.ricoh-imaging.co.jp/english/support/man-pdf/optio-e30.pdf
Instruction manual
Does the SD card have enough room / is it fast enough for video?
(the E30 records Standard def video so it should be OK)
Do you get any error messages at all?
Does it allow you to record video and then fail, or can you not activate recording in the first place?
Pentax Cameras | Answered on Nov 05, 2019
Hi, Penny,
I'm sure you will get a great deal of pleasure out of your new acquisition. To get a manual, try using Google 'Pentax SV camera manual'. You can get a great deal of help, advice and assistance from PentaxForums.com as well.
Pentax Cameras | Answered on Oct 04, 2019
To what camera does this statement (it is not a query) apply ?
Pentax Cameras | Answered on Sep 28, 2019
Hello, Susan -
Fixya.com does not have updated drivers for any computerized equipment.
If you have not already done so, I suggest you contact Pentax directly regarding an updated driver for your Optio RX18.
Pentax is owned by Richoh.
You may be able to find assistance from another Optio RX18 owner through the PentaxForums.com :
https://www.pentaxforums.com/forums/7-pentax-compact-cameras/194995-pentax-optio-rx18-rz18.html
You will need to register (free) to post a question on a forums.
Best wishes.
Pentax Cameras | Answered on Sep 04, 2019
First of all, I assume you are using an SD card (Max 2GB) as that appears to be the maximum the camera can use. That being so, all you need to do is either transfer the contents of the internal memory to the SD card, or to your computer, thus freeing the internal memory. Then set the camera up so that it writes straight to the SD card.
Pentax Cameras | Answered on Aug 23, 2019
Try Google, or contact Ricoh for your country.
Pentax Cameras | Answered on Jul 16, 2019
13-p2huxcneo513p1ejiveg1evd-3-0.jpg What was condition of the battery when it was last used?
If it was fully depleted you are probably going to need a new battery.
Very inexpensive, luckily.
Lithium batteries are superb, but if they are neglected or allowed to fully discharged they are best replaced.
Nice camera
Pentax Cameras | Answered on Apr 03, 2019
Pentax K10D Digital Camera with 18-55mm Lens Logo
5 questions posted
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
K Pentax
  • K Pentax
Most Popular Question
transfer picts pc from olympus stylus
  • Cameras
