20 Most Recent Nikon COOLPIX L10 Digital Camera Questions & Answers
Nikon Coolpix P2 digital camera, can i use it as webcam?
https://www.youtube.com/watch?v=y5-Yvup1nQo
1/6/2018 7:57:54 PM • Nikon COOLPIX... • Answered on Jan 06, 2018
0answers
0answers
Photograph not display my computer
Dear Dr Niaz shah, It may be there is no software installed in ur pc.Just right clik on the image and choose open with option. Here you can find the appropriate option to choose the file with which apps. Ok..now choose any of them. try it. Regards Bikram [email protected]d63b8c69-de1b-4e7a-a325-a0eff9179285.jpg
1/6/2014 7:32:33 AM • Nikon COOLPIX... • Answered on Jan 06, 2014
Can't transfer pictues to computer
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
12/29/2013 5:32:55 PM • Nikon COOLPIX... • Answered on Dec 29, 2013
Memory card is write protected
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
8/7/2013 6:20:55 PM • Nikon COOLPIX... • Answered on Aug 07, 2013
Nikon coolpix l10 digital camera lens error
11/26/2012 10:56:33 AM • Nikon COOLPIX... • Answered on Nov 26, 2012
How do i get my nikon l10 to download to my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
7/6/2012 5:07:57 PM • Nikon COOLPIX... • Answered on Jul 06, 2012
How do i get my nikon L10 digital camera to download to my Dell Vostro laptop
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
7/6/2012 5:07:25 PM • Nikon COOLPIX... • Answered on Jul 06, 2012
THIS CARD CANNOT BE USED
Try reformatting the memory card through your camera, normal under menu or options.If not you may have a different format kind of memory card such as sdhc versus just sd and you camera may not support it
5/26/2012 4:10:25 PM • Nikon COOLPIX... • Answered on May 26, 2012
I have nikon L10. The flash does not work. But it works if I click using self timer
Hi,Try this link below and check if this is the case.Click here -> Nikon L10 TroubleshootingIf that does not help you, try the steps belowClick here - > Alternate MethodRegards,Suhail
5/15/2012 9:34:18 PM • Nikon COOLPIX... • Answered on May 15, 2012
2answers
HELP MY COOLPIX L10 CAMERA VIDEOS FREEZE
I think the problem is your pc. Can you view the video on the camera with out freeze it?
3/14/2012 11:36:09 PM • Nikon COOLPIX... • Answered on Mar 14, 2012
I can't access anymore DCIM and MISC folders on my camera after deleting them using my laptop, is it possible to solve that problem?
If you can't access pictures anymore on your camera, how can you see your photos on your camera?If you already have the pictures downloaded on your computer (which you should have done before starting to delete anything) then you should format the card in the camera. In general you shouldn't do any writing to the card on the computer, leaving it all to the camera.
3/11/2012 5:28:21 PM • Nikon COOLPIX... • Answered on Mar 11, 2012
Why does it shut off immediately?
check the batteries first.
2/8/2012 3:36:02 AM • Nikon COOLPIX... • Answered on Feb 08, 2012
How do I get to formatting so I can delelet all
Press the MENU button. Choose [Set up] and press the OK button. Use the cursor arrows to select "Format memory/Format card" and press OK. Follow the on-screen prompts.
8/1/2011 6:30:15 PM • Nikon COOLPIX... • Answered on Aug 01, 2011
What replaces pictureproject with the coolpix L10
Picture Project was replaced by Nikon Transfer and Nikon ViewNX2. Both of those programs will work perfectly well with the L10. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Once the pictures are on your computer, you can use View NX2 to look at them and do some editing.
7/22/2011 4:39:58 PM • Nikon COOLPIX... • Answered on Jul 22, 2011
2answers
Nikon coolpix L10 lens error fixes? my camera's
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7/14/2011 8:14:57 PM • Nikon COOLPIX... • Answered on Jul 14, 2011
Nikon COOLPIX L10 Digital Camera Logo
189 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
nikon coolpix l10 digital camera lens
  • Cameras
