20 Most Recent AOC 19LVWK LCD Monitor Questions & Answers
My AOC monitor has a
the AOC , connected to what.? a PC ,what PC some PC has video control app that is bad. called DCC2 or eDid controls to the monitor. GONE MAD? if PC is windows, ? is it, put it in to safe mode see if stops this. and or, create a 2nd user, then log off and back on as 2nd user. still fails>? ok last, is in task manager is startup box. in that box disable all start ups there. or ungrade the video card driver at AMD or Nvidia as it may be.
5/13/2022 5:01:41 PM • AOC 19LVWK LCD... • Answered on May 13, 2022
Vertical colour lines ( three lines Bule, Green
NOT ONE PHOTO OF FAILING SCREEN SHOW. POSTED MAKE THIS IMPOSSIBLE FOR MILLIONS TO GUESS. 'WHY? IT IS SAID 1 PHOTO CAN BE WORK A MILLION WORDS FOR LCD PROBLEMS YES. Your cell phone has a CAM use it.? yes AOC is trash. was or is they do not have manual on older monitors as LG and viewsonic have. they are lame. 3inches between them but no one word on line itself thickness, 1 pixel wow
5/3/2022 5:21:00 PM • AOC 19LVWK LCD... • Answered on May 03, 2022
What is the correct resolution
1440 x 900
9/24/2013 11:45:06 AM • AOC 19LVWK LCD... • Answered on Sep 24, 2013
Monitor settings won't go to the brightness
the vga cable is bad
8/16/2013 5:33:56 PM • AOC 19LVWK LCD... • Answered on Aug 16, 2013
manual
When i turn on the computer the LCD show a green light and suddenly they turend in red light and then blank screen showen...what the saolution?
Your PC have display driver problem i am suggest you to run your PC without graphics card if you are you using graphics card.if not then run your PC in network prompt mode and Re installed graphicsdriver.
1/25/2013 6:51:04 AM • AOC 19LVWK LCD... • Answered on Jan 25, 2013
0answers
Hi im having a display
You need to install a better device-driver for the video-adapter on your computer.
When you do, that device-driver will automatically recognize your "Plug-And-Play" monitor.
Open "Control Panel".
Open "System".
Click "Hardware".
Click "Device Manager".
Expand the "video-adapter" part of the tree.
Double-click the video-adapter.
Click "Reinstall Driver".
5/12/2011 6:29:34 PM • AOC 19LVWK LCD... • Answered on May 12, 2011
I have an AOC 19MVWk
It does the same when attached to another PC? It may be indicating that it is in safety shutdown/restart mode due to shorted or failed circuits in the power supply due to bad caps or in the backlights inverter circuits, you need to open it up and inspect the inside and circuits.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
3/16/2011 12:23:01 AM • AOC 19LVWK LCD... • Answered on Mar 16, 2011
Hi I have an AOC M19W monitor attached to my
Top three suspects
1. Change your display cable for a new one 2. Without being able to see the screen myself, try to monitor on a different pc, if your using it as a tv, then try different channels 3. Press and hold the power button for 15 seconds then release to reset the system
2/1/2011 11:41:53 AM • AOC 19LVWK LCD... • Answered on Feb 01, 2011
The menu on my monitor is written in Chinese and i
On the front of the monitor will be a menu button. Press that and you will find the langauge setting to change
?? (chinese text for menu may look like this)
1/16/2011 12:32:49 AM • AOC 19LVWK LCD... • Answered on Jan 16, 2011
2answers
Monitor says no signal
Check the settings on monitor for "input" most of these have multiple input settings and make sure your pc output is set to "mirror"
1/5/2011 1:09:29 PM • AOC 19LVWK LCD... • Answered on Jan 05, 2011
My 19mvwk is saying no signal going to sleep
Check the data cable is properly fixed. Can you hear the beep sound while booting. Check the ram inside the cpu.
12/29/2010 5:05:43 PM • AOC 19LVWK LCD... • Answered on Dec 29, 2010
I have a 22' AOC
Since you did not provide the model number of this 22" AOC monitor, then please look through here:
http://www.aocmonitorap.com/malaysia/user_manual.php
12/18/2010 2:45:31 AM • AOC 19LVWK LCD... • Answered on Dec 18, 2010
Usb port and speaker ports not working
Download the drivers for your Chipsets on your computer manufacturer's website...
9/17/2010 8:16:06 AM • AOC 19LVWK LCD... • Answered on Sep 17, 2010
AOC 19LVWK LCD Monitor Logo
50 questions posted
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Computers & Internet
Most Popular Question
aoc m19w monitor attached
  • Computers & Internet
