20 Most Recent Casio Exilim EX-V7 Digital Camera Questions & Answers
2answers
Dropped my Exilim V7
You have to Call them at 800-706-2534 option 2 and they will tell you where to send your camera to get it fixed. There is nothing that you can do at home to fix that. Sorry.
1/12/2015 5:16:03 AM • Casio Exilim... • Answered on Jan 12, 2015
3answers
My casio exilim Ex-V7 digital camera stabilizer won't work.
The software won't fix your problem. It's the dropping that's causing the camera malfunction.
1/12/2015 4:59:27 AM • Casio Exilim... • Answered on Jan 12, 2015
2answers
Camera stabilizer not available comes
Update it to the newest Firmware. Search it on Casio website. The new firmware turns the stabilizer off. It's a well known problem with the V7. Have updated a lot of these - works every time.
1/8/2015 3:51:49 AM • Casio Exilim... • Answered on Jan 08, 2015
2answers
Exilim casio ex-v7
no the camera does not have a feature for web cam through put but you can get a web cam for like 20.00 on ebay.
1/8/2015 3:46:20 AM • Casio Exilim... • Answered on Jan 08, 2015
0answers
When the camera is on it shows a mesage a mesage on screen that the camera stablizer is not available.
The manual is very simple in this case, it says: The Camera Shake unit may be malfunctioning. If the same message appears after you turn power back on, contact your retailer or a Casio service centre. So if you need the stabilisation (low shutter speeds, you have to go to the repair shop, to let it fix. Try switching off the camera, remove the battery for a few minutes and then place the battery back. Still the same error? you know what to do. Sorry.
12/8/2013 4:28:11 PM • Casio Exilim... • Answered on Dec 08, 2013
2answers
Hi, I am using casio
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
5/24/2013 7:26:41 PM • Casio Exilim... • Answered on May 24, 2013
Can i copy my pictures to my chip
Follow the instructions beginning on page 189 of this manual.
1/22/2013 3:42:25 PM • Casio Exilim... • Answered on Jan 22, 2013
The Lens Error message appears,
1/22/2013 3:36:16 PM • Casio Exilim... • Answered on Jan 22, 2013
How do i upload pics from memory card to pc
Remove the memory card from the camera and plug it into a card reader (either built-in to the computer or connected via USB or FireWire). Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
1/22/2013 3:35:12 PM • Casio Exilim... • Answered on Jan 22, 2013
Casio Exilim EX V7
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1/22/2013 3:32:15 PM • Casio Exilim... • Answered on Jan 22, 2013
How to fix a casio digital camera stabilizer
Out of warranty wont worth fixing. But u can override stab. error by updating special firmware from Casio website. No stabilizing anymore, but u may take pictures again.
1/11/2013 11:11:42 PM • Casio Exilim... • Answered on Jan 11, 2013
Flash is not working. i
YOU MEAN TO SAY THE FLASH OF YOUR CAMERA IS GONE FOR GOOD .IN THAT CASE SOME GOOD TECH HAS TO REPLACE THE SAME. IF NOT SET THE FLASH SETTING TO AUTO. THE ICON WILL BE LIKE A ELECTRIC BOLT ICON.
REGARDS.
PLZ. RATE THIS
7/2/2011 1:03:06 PM • Casio Exilim... • Answered on Jul 02, 2011
3answers
CASIO EXILIM
You don't. That is something that Casio will have to fix. Call 18007062534 and choose option 2. Tell them you have a stabilizer error and they will tell you how to go about sending it in.
7/2/2011 2:33:35 AM • Casio Exilim... • Answered on Jul 02, 2011
2answers
When i slide to take a pic it says that camara
I have a Casio Exilim EX-V7 and I had the same Camera Stabilizer is not available problem, the firmware on my camera was 1.01 (hold down the menu key while sliding the cover open, keep holding until your firmware version displayed) From Casio.com, I downloaded the new firmware 1.03 (you need to register your serial number to do this (put in your serial number ONLY NUMBERS no letters from the bottom of the camera). Run the file you download to extract the bin file needed for the firmware. Connect the camera to your computer. When the folder opens put bin file into that location. MAKE SURE THE CAMERA BATTERY IS CHARGED. Hold down the shutter button (on top) at the same time press and hold the menu button then whil holding those two open the lens cover to power on the camera. It will prompt you on the screen to do the rest. It upgrades very quickly.
Mine still shows the Stabilizer error at startup however, it doesn't turn off and i can take pictures. Have fun and good luck.
Steve
6/26/2011 6:25:35 PM • Casio Exilim... • Answered on Jun 26, 2011
How do I get the annoying programmed background
Press "Menu", Select "Setup Tab", Select "Sounds" press >, then use Arrows UP and Down to select "Operation" Then use " " to select volume 0 to 7, then press "Set" . Setting to Zero "0" will mute the sound. Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
6/26/2011 6:17:59 PM • Casio Exilim... • Answered on Jun 26, 2011
8answers
EX-V7
Thank you so much likoposa! That really helped me! The camera works like a dream again! FixYa! :D
5/2/2011 8:58:59 PM • Casio Exilim... • Answered on May 02, 2011
Casio Exilim EX-V7 Digital Camera Logo
131 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
am using casio
  • Cameras
